Steel head gasket question reuse or use new #1140243
12/20/11 07:51 PM
12/20/11 07:51 PM
Ia.
superstockmopar Offline OP
Ia.
Hello all Merry Christmas , I have a silly question , have a rebuilt 440 but was rebuilt about 6 years ago and never fired , used the Chrysler steel head gaskets at that time , since it was not fired for all those years .. I tore it down cleaned and recheck everything, My Question is can I reuse the steel head gaskets over again since the motor was never run ???? It is just a stock compression 68 440 mild cam 470 lift nothing fancy , I know the head gaskets compress when torqued are theses a throw away and use new ???? Thanks
Re: Steel head gasket question reuse or use new [Re: superstockmopar] #1140244
12/20/11 08:56 PM
12/20/11 08:56 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Yes...they get reaused alot.
Unless you listen to the nay-sayers whove never tried it, but will tell you not to.
Re: Steel head gasket question reuse or use new [Re: NTOLERANCE] #1140245
12/20/11 09:02 PM
12/20/11 09:02 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I agree, run them.
Re: Steel head gasket question reuse or use new [Re: ireland383] #1140246
12/20/11 09:17 PM
12/20/11 09:17 PM
Ia.
Ia.
Thanks, my thoughts exactly , re use we do
Re: Steel head gasket question reuse or use new [Re: superstockmopar] #1140247
12/20/11 10:29 PM
12/20/11 10:29 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Here we go again...my post from a few days ago:
https://board.moparts.org/ubbthreads/show...e=2#Post6971130
Re: Steel head gasket question reuse or use new [Re: superstockmopar] #1140248
12/20/11 11:05 PM
12/20/11 11:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Spray gasket with aluminum paint and bolt together.
Re: Steel head gasket question reuse or use new [Re: MoparforLife] #1140249
12/21/11 02:31 AM
12/21/11 02:31 AM
Yes several light coats of good quality aluminum spray paint and a flat deck/heads required
Re: Steel head gasket question reuse or use new [Re: RapidRobert] #1140250
12/21/11 11:20 AM
12/21/11 11:20 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
aren't the steel shims/gaskets fully re-useable? even after the engine's been run?
**Photobucket sucks**
Re: Steel head gasket question reuse or use new [Re: 70Cuda383] #1140251
12/21/11 11:30 AM
12/21/11 11:30 AM
After firing for the head gaskets dead soft copper yes steel no, intake can get by w it and I'd even be leery of reusing these esp as they are so cheap but I think with some good spray alum paint he'll be OK IF the surfaces were both milled (or competently checked & found to be flat)during the rebuild EDIT and alum spray should be used the 1st time too
