Re: Steel head gasket question reuse or use new
[Re: superstockmopar]
#1140244
12/20/11 08:56 PM
12/20/11 08:56 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Yes...they get reaused alot.
Unless you listen to the nay-sayers whove never tried it, but will tell you not to.
[Re: MoparforLife]
#1140249
12/21/11 02:31 AM
12/21/11 02:31 AM
RapidRobert
Yes several light coats of good quality aluminum spray paint and a flat deck/heads required
[Re: RapidRobert]
#1140250
12/21/11 11:20 AM
12/21/11 11:20 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
aren't the steel shims/gaskets fully re-useable? even after the engine's been run?
**Photobucket sucks**
[Re: 70Cuda383]
#1140251
12/21/11 11:30 AM
12/21/11 11:30 AM
RapidRobert
After firing for the head gaskets dead soft copper yes steel no, intake can get by w it and I'd even be leery of reusing these esp as they are so cheap but I think with some good spray alum paint he'll be OK IF the surfaces were both milled (or competently checked & found to be flat)during the rebuild EDIT and alum spray should be used the 1st time too
