HVH Super Suckers... #1139252
12/19/11 10:55 AM
12/19/11 10:55 AM
tboomer Offline OP
tboomer  Offline OP
Are they worth it or just snake oil?
Re: HVH Super Suckers... [Re: tboomer] #1139253
12/19/11 12:19 PM
12/19/11 12:19 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Good question,T-Boom! I'd like to see some dyno-testing results....preferably on a .040 over 440 with cnc-ported Eddy Performer RPM's..M-1 intake..950 Holley..solid flat tappet cam with 260 duration @ .050,.600-.620 lift,and 2"x 3.5"collector headers!
Re: HVH Super Suckers... [Re: Labratt] #1139254
12/19/11 12:21 PM
12/19/11 12:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have a 1 inch one for a dominator let go cheap you could try.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: HVH Super Suckers... [Re: Labratt] #1139255
12/19/11 12:22 PM
12/19/11 12:22 PM
tboomer Offline OP
tboomer  Offline OP
Hi,Randy! The reason I ask is they are not cheap! My current setup is a Mr.G 4500 to 4150 intake on a Victor...My spacer is 2"....
Re: HVH Super Suckers... [Re: tboomer] #1139256
12/19/11 12:29 PM
12/19/11 12:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Just like every other spacer, it depends on the combination as to whether they show an improvement.
Re: HVH Super Suckers... [Re: BradH] #1139257
12/19/11 12:33 PM
12/19/11 12:33 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes it is just trial and error to see if it works for your setup. I had a wilson tappered spacer on my old motor (4150) and it would pick up .05.
Re: HVH Super Suckers... [Re: 1967dartgt] #1139258
12/19/11 12:38 PM
12/19/11 12:38 PM
tboomer Offline OP
tboomer  Offline OP
I also looked into the Wilson 1 1/2" 4500 to 4150 intake spacer...I n reality it would be nice to test both! However...Money says I can only try one!
Re: HVH Super Suckers... [Re: tboomer] #1139259
12/19/11 12:50 PM
12/19/11 12:50 PM
dogdays Offline
dogdays  Offline
Most published dyno results show an improvement greater than testing error.
R.
Re: HVH Super Suckers... [Re: dogdays] #1139260
12/19/11 02:18 PM
12/19/11 02:18 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We tested a 2" one at the end of the season on the 512RB and no change in ET or 60ft, mph, nada. For the record though, we only run a 950 carb, and the intake has a fairly large plenum. I look forward to testing it on my 408 stroker next season. That intake has a small plenum, and I suspect it will pick-up.
Re: HVH Super Suckers... [Re: Dragula] #1139261
12/19/11 02:24 PM
12/19/11 02:24 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have just bought an alloy 2" supersucker for $60 new off RJ. I intend to try it first meet out next year but will swap at the track and jet to see what it likes, 2 engine guys on here highly recommended them, one being Dwayne.
Randy my set up is very similar to yours engine wise.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: HVH Super Suckers... [Re: Dragula] #1139262
12/19/11 02:25 PM
12/19/11 02:25 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I plan to back to back a 2" HVH on my 414 with a ported Victor 340 and Stage 2 Shady Dell E heads in the early spring. As said it's trial and error, I think it might have been Joe Sherman that tested one that picked up Hp, and when he was taking it off he discovered he installed it upside-down.
WIZE
In Car:
Re: HVH Super Suckers... [Re: tboomer] #1139263
12/19/11 02:51 PM
12/19/11 02:51 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
he ted pm Doctor Doug aka 69chargermd i think he is useing one on the 65.but i dont remember if he picked up any or not with it on his car.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: HVH Super Suckers... [Re: mopar65] #1139264
12/19/11 03:34 PM
12/19/11 03:34 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
2" super sicker spacer 572 B1 picked up 16HP on the dyno. Thet's the only real dyno info I have.
Re: HVH Super Suckers... [Re: camastomcat] #1139265
12/19/11 04:02 PM
12/19/11 04:02 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
Maybe Quick D100 of Dave's performance will chime in. On Dave's Dyno
My 512 made only 4 more hp but 20 more ft. lbs. tq. with the 2" super sucker.
Re: HVH Super Suckers... [Re: tboomer] #1139266
12/19/11 04:23 PM
12/19/11 04:23 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Ted,
I have one of Wilson's 1 1/2" adapters if you want to try it,it is just an open spacer/adapter,if that is what you are looking at.
I also have one of the 2" Moroso(I believe) adapters,just let me know.
Keith
Re: HVH Super Suckers... [Re: tboomer] #1139267
12/19/11 04:47 PM
12/19/11 04:47 PM
AndyF Offline
AndyF  Offline
Carb spacers almost always pick up power on the dyno. I run a custom built 4 inch carb spacer on the bigger motors on the dyno just for that reason.
They sometimes don't work quite as well on a car unless the accel pump is reworked for additional volume.
Trial and error is the only way to find out.
Re: HVH Super Suckers... [Re: tboomer] #1139268
12/19/11 07:45 PM
12/19/11 07:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I tried one once and she was INCREDIBLE......
Re: HVH Super Suckers... [Re: Thumperdart] #1139269
12/19/11 09:57 PM
12/19/11 09:57 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
2" Dominator to 4150 adapter did nothing for me. The HVH one that is, I went back to the Moroso open adapter.
Re: HVH Super Suckers... [Re: 540dust] #1139270
12/20/11 09:30 AM
12/20/11 09:30 AM
tboomer Offline OP
tboomer  Offline OP
Thanks everyone for the info! Keith...That is a nice offer but I would rather buy my own...Won't do anything over the winter...
Re: HVH Super Suckers... [Re: tboomer] #1139271
12/20/11 10:04 AM
12/20/11 10:04 AM
an8sec70cuda Offline
A 1" HVH was worth about a tenth and 1 mph on my old 446" Indy SR headed combo. That motor had a Team G manifold and a 1050 dominator on it.
Didn't gain anything on my hemi w/ the Ray Barton manifold. Haven't tried it yet on the Indy manifold.
CHIP
'06 GMC 2500HD LBZ Duramax
