Tips on Removing Axle Bearings?
#1139061
12/19/11 12:15 AM
12/19/11 12:15 AM
Posts: 773 San Antonio, Tx
bulletpruf
San Antonio, Tx
Fellas -
I have to remove a few sets of axle bearings - one from a Pontiac 8.2" 10 bolt and one from an AMC 20. I have a press which I can use to put new bearings on, but can't see how I could use it to remove the old bearings.
I've used the cutoff wheel method before, but don't want to go that route this time. I'd rather not booger up either set of axles or retainer plates.
Any tips here? There has to be a better way. If there's a tool that I need, I'm fine with that, too.
Thanks!
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Tips on Removing Axle Bearings?
[Re: Dodgem]
#1139063
12/19/11 12:41 AM
12/19/11 12:41 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You can use the bearing splitter posted above or as you mentioned a cutoff wheel, if you use the splitter you should use a chisel & cut four deep notches in the bearing retainer which is the ring that presses on after the bearing.... It locks the bearing & unless you have a pretty big press you probably won't move the bearing..
I've had good results using a dremel with a small cut off wheel to cut off the out bearing race than cut a groove in the inner race, not all the way through the inner race just about halfway then slam it with a hammer& the race will fracture... Then it slides off pretty easy...
On the AMC Axle the early ones have a bolt on wheel flange & the bearing comes off to the outboard end of the axle..
[Re: 1_WILD_RT]
#1139064
12/19/11 09:42 AM
12/19/11 09:42 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
i have never removed axle bearings. i drop them off at a friends shop and he does it. i have been told that the retainer ring is hardened steel. because of this take a SHARP chisel and strike the collar a few times. because it is hardened most of the time it just shatters and breaks. if it doesn't do it turn the axle 180* and repeat.
perception is 90% of reality
[Re: bulletpruf]
#1139066
12/19/11 11:40 AM
12/19/11 11:40 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I have the tool pictured here - http://www.harborfreight.com/automotive-motorcycle/pullers/large-bearing-separator-3979.html
I also have the Harbor Freight 20 ton press.
Maybe I'm not doing something right, but I can't figure out how to configure things to press the bearing off.
If I stand the axle on the end, hub down, splines up, on the press, the axle flange will not fit between the bottom support of the press. I don't have anything to use to support the bearing separator as I press the axle down.
Am I making sense here?
Scott
Then you need to support the bearing seperator up off the bottom support. I don't know what the axles and bearing you are working on look like but When I take apart and 8.75 or dana axle I cut the oter race off , pull the cage and rollers and pull the inner race off . I have also cut the inner race, but not all the way thru, then a few whacks with a hammer and it splits .
[Re: JohnRR]
#1139067
12/19/11 12:15 PM
12/19/11 12:15 PM
bulletpruf
San Antonio, Tx
Scott
Therein lies the problem. I've tried blocking the bearing separator up with 2x4's and 4x4's, but it won't hold up when I start pressing. Thinking if I jammed/wedged in a few jackstands at an angle that might work.
Scott
[Re: 1_WILD_RT]
#1139072
12/19/11 02:26 PM
12/19/11 02:26 PM
Posts: 1,443 Maryland
Dads426
Maryland
After cutting off the bearing cage, I've never been able to get a splitter behind the race, so I have always used 1_WILD_RT's method of using a Dremel (the smaller diameter cutoff wheels allow you to get closer to the cheek on the axle) and just split the collar and race with a chisle while being supported on an anvil.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1139073
12/19/11 03:30 PM
12/19/11 03:30 PM
JohnRR
U.S.S.A.
I never try to get it behind the race , the lip the rollers ride against closet to the retainer rig is where I put the splitter and they have alawys come right off .
[Re: bulletpruf]
#1139078
12/19/11 09:40 PM
12/19/11 09:40 PM
Posts: 7,664 IN
ahy
IN
Scott
There are folks who have made custom fixtures to press the bearings off... including a machine shop I work with from time to time. This IS NOT the recommended way though. It takes a very large force on a long slender axle which is dangerous. The guy that did it for me last time said the pressure guage on his press went way to the right before it let go with a big bang that made him jump. His was a professional press and he has done many of these.
Side cutters to get the cage off then the chisle is the recommended way for a reason...
[Re: ahy]
#1139080
12/19/11 10:59 PM
12/19/11 10:59 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
I have seen the same thing when the press operator DIDN"T remove the bearing retaining collar first , double press fit doubles the required amount of pressure needed to get the bearing moving Common sense is needed anytime your working on or operating equiptment,cars, airplanes, boats, women and horses
