Re-Use Head Gaskets On A Motor Not Fired? #1137676
12/17/11 01:40 PM
12/17/11 01:40 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
I put the heads on a fresh 318 short block and torqued them down last weekend. Now I gotta take 'em off - long story, don't ask.
Can I re-use the head gaskets, since it's never been fired? They're basic rebuilder composites.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: vdriver] #1137677
12/17/11 01:49 PM
12/17/11 01:49 PM
Kirkland, Washington
Pacnorthcuda Offline
I gonna opine that it would be better if you didn't, but I would be willing to bet that you would get-away with 're-using' them just fine.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: Pacnorthcuda] #1137678
12/17/11 02:27 PM
12/17/11 02:27 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
you have to ask yourself how much work will i have to do if this doesn't work viruses what will it cost me to do it right the first time?
only you can answer this question.
perception is 90% of reality
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: Mr T2U] #1137679
12/17/11 02:51 PM
12/17/11 02:51 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Done it several times.....
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: NTOLERANCE] #1137680
12/17/11 05:25 PM
12/17/11 05:25 PM
I have done it--don't worry--do it.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: NTOLERANCE] #1137681
12/17/11 05:33 PM
12/17/11 05:33 PM
Me too
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: Cab_Burge] #1137682
12/17/11 09:05 PM
12/17/11 09:05 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Me too
Go for it!
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: vdriver] #1137683
12/18/11 12:43 AM
12/18/11 12:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did it on my currant race engine... it turns 8200
RPMs and it doesnt have any problems(its 14.1:1 compression)
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: MR_P_BODY] #1137684
12/18/11 11:13 AM
12/18/11 11:13 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Well that pretty much clinches it.
Thanks everyone; it looks like they're going back on.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: MR_P_BODY] #1137685
12/18/11 12:51 PM
12/18/11 12:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Really? You're running a cheapo rebuilder's head gasket on this? I seriously doubt it.
Can you reuse a head gasket? Yes, but the question is for how long now isn't it? I'd look at it like this, what would be required if I reused it and it failed? and is that less than the cost of another set of cheapo rebuilder's gaskets? (doubt it)
Don't be the exception.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: Supercuda] #1137686
12/18/11 01:11 PM
12/18/11 01:11 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I lost a cam in my 470" after 800 mi. Used the gaskets over.....now has about 3k mi. on it,no problems.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: Mr T2U] #1137687
12/18/11 01:30 PM
12/18/11 01:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ditto,
Would it work? Maybe/probably
Is it worth it to me ? nope
Not worth the gamble to me.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: vdriver] #1137688
12/18/11 02:31 PM
12/18/11 02:31 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
So, to the guys saying "Dont reuse them, I wouldnt".....
You never reused a head gasket?
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: NTOLERANCE] #1137689
12/18/11 03:48 PM
12/18/11 03:48 PM
I have seen Bob Reed pull the heads off his SS Hemi--throw the steel shim gasket down, put the head back on with no more than a wipe of the gasket with a rag--Then go out and run another rocking wheels in the air pass. When asked about it --the gasket had been on and off lots of times.
Now I know he runs a radiator cap with no pressure and all that but.....
You guys tell me how tightening a head gasket down the taking it loose--then putting it right back on can in any way mess that gasket up.
Go to the Smithsonian and just LOOK at a Mercury space capsule--Guys flew them into outer space and they look as if they were built in a back yard garage---
Don't worry so much--Hot Rod like the old days and keep it fun and as CHEAP as possible.
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: ] #1137690
12/18/11 04:39 PM
12/18/11 04:39 PM
hooziewhatsit Offline
As long as chunks don't come off the gasket, or it doesn't rip, I'd probably re-use it
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: Supercuda] #1137691
12/18/11 04:41 PM
12/18/11 04:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Felpo gaskets on a W-9 head... do what you want...
but if it hasnt been heat cycled I dont have any
problem
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: MR_P_BODY] #1137692
12/18/11 08:41 PM
12/18/11 08:41 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
problem
not going to hurt a thing
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: dusturbd340W5] #1137693
12/18/11 09:05 PM
12/18/11 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
problem
Its funny because I have AT LEAST 20-30 sets of head
gaskets hanging on the wall of my build room so IF
I thought it was a issue I'd grab another set and
put them on........ but I dont
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: MR_P_BODY] #1137694
12/18/11 10:43 PM
12/18/11 10:43 PM
Kissimmee Fl.
Kissimmee Fl.
problem
yep no reason to
Re: Re-Use Head Gaskets On A Motor Not Fired? [Re: NTOLERANCE] #1137695
12/24/11 04:19 AM
12/24/11 04:19 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ditto... done it to with no ill effects
