Re: Re-Use Head Gaskets On A Motor Not Fired?
[Re: Pacnorthcuda]
#1137678
12/17/11 02:27 PM
12/17/11 02:27 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
you have to ask yourself how much work will i have to do if this doesn't work viruses what will it cost me to do it right the first time? only you can answer this question.
perception is 90% of reality
[Re: Mr T2U]
#1137679
12/17/11 02:51 PM
12/17/11 02:51 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Done it several times.....
[Re: NTOLERANCE]
#1137680
12/17/11 05:25 PM
12/17/11 05:25 PM
I have done it--don't worry--do it.
[Re: Cab_Burge]
#1137682
12/17/11 09:05 PM
12/17/11 09:05 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Me too
Go for it!
[Re: MR_P_BODY]
#1137684
12/18/11 11:13 AM
12/18/11 11:13 AM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
I did it on my currant race engine... it turns 8200 RPMs and it doesnt have any problems(its 14.1:1 compression)
Well that pretty much clinches it.
Thanks everyone; it looks like they're going back on.
[Re: Mr T2U]
#1137687
12/18/11 01:30 PM
12/18/11 01:30 PM
Posts: 21,490 It's a dry heat
gtx6970
It's a dry heat
Ditto, Would it work? Maybe/probably
Is it worth it to me ? nope
Not worth the gamble to me.
[Re: vdriver]
#1137688
12/18/11 02:31 PM
12/18/11 02:31 PM
NTOLERANCE
Madison Wi
So, to the guys saying "Dont reuse them, I wouldnt".....
You never reused a head gasket?
[Re: NTOLERANCE]
#1137689
12/18/11 03:48 PM
12/18/11 03:48 PM
I have seen Bob Reed pull the heads off his SS Hemi--throw the steel shim gasket down, put the head back on with no more than a wipe of the gasket with a rag--Then go out and run another rocking wheels in the air pass. When asked about it --the gasket had been on and off lots of times. Now I know he runs a radiator cap with no pressure and all that but..... You guys tell me how tightening a head gasket down the taking it loose--then putting it right back on can in any way mess that gasket up. Go to the Smithsonian and just LOOK at a Mercury space capsule--Guys flew them into outer space and they look as if they were built in a back yard garage--- Don't worry so much--Hot Rod like the old days and keep it fun and as CHEAP as possible.
[Re: Supercuda]
#1137691
12/18/11 04:41 PM
12/18/11 04:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Really? You're running a cheapo rebuilder's head gasket on this? I seriously doubt it.
Can you reuse a head gasket? Yes, but the question is for how long now isn't it? I'd look at it like this, what would be required if I reused it and it failed? and is that less than the cost of another set of cheapo rebuilder's gaskets? (doubt it)
Felpo gaskets on a W-9 head... do what you want... but if it hasnt been heat cycled I dont have any problem
[Re: dusturbd340W5]
#1137693
12/18/11 09:05 PM
12/18/11 09:05 PM
MR_P_BODY
not going to hurt a thing
Its funny because I have AT LEAST 20-30 sets of head gaskets hanging on the wall of my build room so IF I thought it was a issue I'd grab another set and put them on........ but I dont
