Re: intake porting
[Re: Brian Hafliger]
#1135216
03/16/12 01:50 PM
03/16/12 01:50 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Y'all gonna have a vendor spot at spring fling? Will you have any of the indy 360-3R intakes there as I need one? If you do go ahead and have one ported for the 245CNC 360-1 heads and I'll be there to pick it up DEPUTY
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: intake porting
[Re: CRIKEY]
#1135219
09/06/13 09:59 PM
09/06/13 09:59 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I never got around to testing back to back, but I can say that if your going to a dominator carb, the plenum should be done correctly. I've seen this mod support very close to 800HP N.A.
The intake OOTB only really needs work from the flange in about 3". The OOTB plenum is pretty darn good as it is. Brian
Brian Hafliger
Re: intake porting
[Re: Wedgeman]
#1135222
09/09/13 06:22 AM
09/09/13 06:22 AM
Posts: 28 AUSTRALIA
CLEVO351
AUSTRALIA
My dyno results yesterday showed best peak hp at 37* locked timing advance
605hp on a 408ci at 6300 rpm 552 lbs at 5100 rpm
Dan
Jezz ! that sounds like a lot of timing for that chamber, is that with a dome piston? and what compression and fuel are you running ?
