Door locks- 63 Dodge #1135106
12/16/11 06:11 AM
12/16/11 06:11 AM
Rochester, NY
Red63440 Offline OP
Red63440  Offline OP
Rochester, NY
I was able to get a complete set of door locks, trunk lock and ignition from a donor car. I had one lock in the drivers door which I removed prior to having it painted. I must have screwed with the one door lock for 30 min. tonight and can't figure out how to get it installed. Is there a right and a left and can anyone lend a bit of insite?
Thanks!
68 Barracuda Fastback
Re: Door locks- 63 Dodge [Re: Red63440] #1135107
12/16/11 09:23 AM
12/16/11 09:23 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes they are L&R.Put the key in the lock.It should be teeth facing up.Then they slide in.Hardest part is connecting the lock rod.Rocky
Chrysler Firepower
Re: Door locks- 63 Dodge [Re: therocks] #1135108
12/16/11 11:28 AM
12/16/11 11:28 AM
Rochester, NY
Red63440 Offline OP
Red63440  Offline OP
Rochester, NY
Thats where the problem is, its a real pain in the azz.
Re: Door locks- 63 Dodge [Re: Red63440] #1135109
12/16/11 11:53 AM
12/16/11 11:53 AM
RapidRobert Online content
RapidRobert  Online Content
didn't know earlier door locks were side specific
Re: Door locks- 63 Dodge [Re: RapidRobert] #1135110
12/16/11 12:51 PM
12/16/11 12:51 PM
Rochester, NY
Red63440 Offline OP
Red63440  Offline OP
Rochester, NY
That makes two of us....
Re: Door locks- 63 Dodge [Re: Red63440] #1135111
12/18/11 02:40 PM
12/18/11 02:40 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
had the same delema with my 62 just make sure you have good lighting and lots of patients..
