tcs trans 'full metal jacket' drum #1134935
12/15/11 09:11 PM
12/15/11 09:11 PM
southwest pa
bodyworks racing Offline OP
southwest pa
still running a stock front drum and it makes me nervous.going to replace it when we go thru the trans . anybody use or know anyboby that uses tcs steel sleeved drum?
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: tcs trans 'full metal jacket' drum [Re: bodyworks racing] #1134936
12/15/11 09:17 PM
12/15/11 09:17 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I am going-to-be along with you ..
Oh ...and is there steel on the ring surface?
Re: tcs trans 'full metal jacket' drum [Re: bodyworks racing] #1134937
12/15/11 09:45 PM
12/15/11 09:45 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have the 6 clutch steel drum they sell,its a nice work of art...b1 johnny hooked me up with it good investment!
Re: tcs trans 'full metal jacket' drum [Re: dOc !] #1134938
12/15/11 10:31 PM
12/15/11 10:31 PM
southwest pa
southwest pa
it has a steel sleeve around the band surface. the rest is billet aluminum.just want to find out more before i shell out 625
Re: tcs trans 'full metal jacket' drum [Re: bodyworks racing] #1134939
12/15/11 11:04 PM
12/15/11 11:04 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
i have that drum in bl racings duster. he went a tenth quicker.he had a select unit it exploded at atco,i built him a new oneits mint. happy holidays johnny
Re: tcs trans 'full metal jacket' drum [Re: fishy340] #1134940
12/15/11 11:43 PM
12/15/11 11:43 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
B1 Johnny hooked me up also,I got the billet steel
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: tcs trans 'full metal jacket' drum [Re: bodyworks racing] #1134941
12/16/11 12:14 AM
12/16/11 12:14 AM
fullmetaljacket Offline
Hey! Who's using my name with out permission? LOL.
Yeah, I've heard of the Select stuff going puff, or should I say Bam!
Curt Sr. at The Bergen Garage will set it up right the first time. He knows all the Voodoo behind every unit and calls out all the fakes.
Re: tcs trans 'full metal jacket' drum [Re: fullmetaljacket] #1134942
12/16/11 01:05 AM
12/16/11 01:05 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my current trans is full of TCS parts & they are works of art when you compare them to the stockers. i'm collecting parts to build a spare trans & will probably go with the full metal jacket drum along with their billet low reverse drum in the back up trans. the current trans' TCS billet steel drum has already saved me when the dumbass who built my trans first time failed on the sprag rebuild. blown sprag & still ran 10 zero.
Re: tcs trans 'full metal jacket' drum [Re: hemi-itis] #1134943
12/16/11 02:16 AM
12/16/11 02:16 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Does that drum require any additional machining to install?
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: tcs trans 'full metal jacket' drum [Re: Hemi Allstate] #1134944
12/16/11 08:27 AM
12/16/11 08:27 AM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
the rear clutch drum has to be clearanced.there is a chamfer onthe drumyou have to make it wider instructions are included with the drum.
Re: tcs trans 'full metal jacket' drum [Re: B1Johnny] #1134945
12/16/11 10:30 AM
12/16/11 10:30 AM
southwest pa
southwest pa
thanks for the replies guess i will pull the trigger and call them today merry christmas to me
Re: tcs trans 'full metal jacket' drum [Re: bodyworks racing] #1134946
12/16/11 10:47 AM
12/16/11 10:47 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Just "Raw" alum in the reaction shaft sealing ring area ? ... what do they recommend for sealing rings then ....so the rings don't tear-up the drum ??
Re: tcs trans 'full metal jacket' drum [Re: dOc !] #1134947
12/16/11 06:31 PM
12/16/11 06:31 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
It has a brass ring machined for the seal ring area.
http://www.tcsproducts.com/products/product/369/
Re: tcs trans 'full metal jacket' drum [Re: PC-CHARGER] #1134948
12/16/11 07:18 PM
12/16/11 07:18 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
PC ... that link is not werkin' furr me ... brass ? ...why not steel? .... all considered at this point .. my choice is leaning towards a steel drum.
BUT NOT the one that has a lot of clutch discs.
Re: tcs trans 'full metal jacket' drum [Re: dOc !] #1134949
12/16/11 08:17 PM
12/16/11 08:17 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Not sure why they decided to use brass but here's a picture. Maybe it has to do with the expansion rates of the materials. Brass likely expands at a rate closer to that of aluminum than steel.
As for sealing rings, teflon rings are included with the drum.
Re: tcs trans 'full metal jacket' drum [Re: PC-CHARGER] #1134950
12/16/11 08:37 PM
12/16/11 08:37 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Is this drum Race only or can you use it on a moderately used street car ?
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: tcs trans 'full metal jacket' drum [Re: keefe] #1134951
12/16/11 09:01 PM
12/16/11 09:01 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi,
I have this drum in my car and I'm happy with it, I chose it cause I freshen several friends trans with the alum drum and I don't care for the wear on the drum from the band , also the alum crap all over the inside of the trans also. I think its' a happy medium between alum and billet steel.
Russ
Re: tcs trans 'full metal jacket' drum [Re: keefe] #1134952
12/16/11 09:53 PM
12/16/11 09:53 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Not strictly a race piece and like already has been said, the steel "jacket" reduces the wear from the band that the aluminum drum suffers from and it is lighter than the full steel unit.
Re: tcs trans 'full metal jacket' drum [Re: dOc !] #1134953
12/16/11 11:53 PM
12/16/11 11:53 PM
hemi-itis Offline
hemi-itis  Offline
Doc,it seems that to use the extra disc,the thinner ones need to be used.My trans guy Tom preferred the thicker clutch disc so it's still,,,,,,,5 I think
I can ask Tom or B1 Johnny will say
Re: tcs trans 'full metal jacket' drum [Re: hemi-itis] #1134954
12/17/11 02:49 AM
12/17/11 02:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i tried 6 disc's in my billet steel drum from TCS. i had a lot of overheating probs with the trans. we pulled it down & rebuilt with five fat disc's. seems to run cooler this rebuild.
