Page 1 of 3 1 2 3
How do you "use" feeler gauges #1134587
12/15/11 02:54 PM
12/15/11 02:54 PM
Florida STAYcation
dOOc Online penguin-006 OP
The village idiot's idiot
dOOc  Online Penguin-006 OP
Florida STAYcation
.... like checking rod-side-clearance ORE ring-groove-clearance.... what kind of "pressure" do you use in the insertion of that feeler into the slot?
Re: How do you "use" feeler gauges [Re: dOOc] #1134588
12/15/11 03:01 PM
12/15/11 03:01 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when we do rockers we're just looking for a slight drag on the blade as we pull it thru.
Re: How do you "use" feeler gauges [Re: rebel] #1134589
12/15/11 03:06 PM
12/15/11 03:06 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Use a slightly larger gauge as a no-go and the size you want as a "go".
Re: How do you "use" feeler gauges [Re: dOOc] #1134590
12/15/11 03:10 PM
12/15/11 03:10 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
It should slip in tight with no wiggle, if it fits in between the rods it's right. Light oil (like wd-40) wipe on the feeler.
Now on a roller rocker on a valve stem I'll generally use a .002 fatter feeler than I want the lash to be and tighten the rocker/roller down until I can get the same slight tug on the feeler to pull it out....but that's just me
WIZE
In Car:
Re: How do you "use" feeler gauges [Re: bobby66] #1134591
12/15/11 03:12 PM
12/15/11 03:12 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I got a stepped feeler gauge many years ago, maybe from Snap-On? I think. Made checking things a lot easier.
Re: How do you "use" feeler gauges [Re: dOOc] #1134592
12/15/11 03:17 PM
12/15/11 03:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Well... they're called "feeler" gauges, not "jam-it" gauges; I figure if you're forcing it in at all that you're not getting an accurate measurement.
Re: How do you "use" feeler gauges [Re: BradH] #1134593
12/15/11 03:47 PM
12/15/11 03:47 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That's what she... Oh never mind
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: How do you "use" feeler gauges [Re: BradH] #1134594
12/15/11 04:00 PM
12/15/11 04:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes but if the gauge has a slight angle to the clearance your checking it will "feel" like the gap is correct... As Wise suggested using the next bigger gauge and getting moderate tension isn't a bad method.. For valves I use a Go/NoGo gauge, for rod clearance where seeing the proper angle is easy I use a standard gauge & expect a light pull...
Re: How do you "use" feeler gauges [Re: BloFish] #1134595
12/15/11 04:13 PM
12/15/11 04:13 PM
Florida STAYcation
Florida STAYcation
.... what ...like a 3/8 stem ...with 006 clearance ? ..
Re: How do you "use" feeler gauges [Re: dOOc] #1134596
12/15/11 04:22 PM
12/15/11 04:22 PM
Orlando Florida
blown572dart Offline
Orlando Florida
between my fingers
Re: How do you "use" feeler gauges [Re: dOOc] #1134597
12/15/11 05:00 PM
12/15/11 05:00 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
plain & simple. snug. no pressure. seeya
Re: How do you "use" feeler gauges [Re: bobby66] #1134598
12/15/11 05:16 PM
12/15/11 05:16 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: How do you "use" feeler gauges [Re: bobby66] #1134599
12/15/11 05:59 PM
12/15/11 05:59 PM
I use the recommendations of a old Mopar engine guru, if it slides in easy it is to loose,he said it should almost cut your finger to make it slide in. I now use the go no go procedure, if a .016 will go in hard and a .017 won't go in no matter how hard I press on it I'm there at .016
Re: How do you "use" feeler gauges [Re: BloFish] #1134600
12/15/11 06:20 PM
12/15/11 06:20 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That's the inside mic... Prefer an interference fit!
Re: How do you "use" feeler gauges [Re: Cab_Burge] #1134601
12/15/11 08:15 PM
12/15/11 08:15 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I've used the "go, no-go" technique for many years. Usually a .002 difference as mentioned.
Re: How do you "use" feeler gauges [Re: Cab_Burge] #1134602
12/16/11 12:23 AM
12/16/11 12:23 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Yup, if it fits, thats what it is. I used to set mine by the "run it down till snug and set it" routine, (for rockers) then found if I put a bit of pressure on the next larger feeler it would go in too. I like to set it so that I get a loud "snap" when I remove the feeler, but still just be able to put it back in. That 1 or 2 thou difference though, in most cars, will make little or no difference in performance so I dont get in a twist over it. Just my
Re: How do you "use" feeler gauges [Re: Cab_Burge] #1134603
12/16/11 12:48 PM
12/16/11 12:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
thats how I was taught to do it.
Re: How do you "use" feeler gauges [Re: dartman366] #1134604
12/16/11 01:47 PM
12/16/11 01:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Doc if you have to ask that question you better stick to fiberglass where you can get close and not worry about it
Re: How do you "use" feeler gauges [Re: Quicktree] #1134605
12/16/11 01:59 PM
12/16/11 01:59 PM
Guitar Jones Offline
Just a slight drag on the gauge. Jamming it or forcing it is not an accurate measurement. Do you clamp a micrometer like a pair of vise grips?
Re: How do you "use" feeler gauges [Re: Guitar Jones] #1134606
12/16/11 02:01 PM
12/16/11 02:01 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Page 1 of 3 1 2 3
