440 head is it a good one to build?? #113361
09/01/08 02:09 AM
09/01/08 02:09 AM
Wa,Whatcom
ta70mopar Offline OP
Wa,Whatcom
Cast number 2951250 is that a good head to build? Just picked up a 383 and it has these heads on it. What I have found it is a 68 440. Is that a good head for a 383. thanks Also is that a closed or opened chamber
Re: 440 head is it a good one to build?? [Re: ta70mopar] #113362
09/01/08 09:56 AM
09/01/08 09:56 AM
God's Country Maryland
GODSCOUNTRY340 Offline
That head was used on '68 383 & 440. They are open chamber with 2.08/1.74 valves.
Re: 440 head is it a good one to build?? [Re: GODSCOUNTRY340] #113363
09/01/08 10:58 AM
09/01/08 10:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Depends what they need.Usually you will have more in them than a good set of new aluminum will cost.Rocky
Chrysler Firepower
Re: 440 head is it a good one to build?? [Re: therocks] #113364
09/01/08 11:05 AM
09/01/08 11:05 AM
I would search for a set of reasonably priced 915's for the closed chambers or spring for aluminum ones again for the very desireable closed chamber & with pistons to match to get proper quench.
Re: 440 head is it a good one to build?? [Re: RapidRobert] #113365
09/01/08 01:24 PM
09/01/08 01:24 PM
Wa,Whatcom
Wa,Whatcom
thanks figured that would be the thing did not see much on the net about the heads I have
Re: 440 head is it a good one to build?? [Re: ta70mopar] #113366
09/01/08 02:33 PM
09/01/08 02:33 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
It depends a lot on what your goals are.
You will find that most comparison test info, shows that almost all the open chambered oem heads perform about the same if ported by the same guy.
If it's a cruiser car, thaose are more than good enough.
Re: 440 head is it a good one to build?? [Re: dave571] #113367
09/01/08 02:35 PM
09/01/08 02:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yeah, if you just want a rebuilt stock head, they're fine. If you want porting, big valves, etc, then I suggest you take a look at some aftermarket heads. For the $ you have to put into cast iron heads, aluminums might not be much more $.
Re: 440 head is it a good one to build?? [Re: DaytonaTurbo] #113368
09/02/08 12:04 AM
09/02/08 12:04 AM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
I've only come across 1 set of the 250 heads and they were an open chambered 2.08/1.74 valve head with the late model 516 head ex. port roof lump near the manifold flange.
Randy
Re: 440 head is it a good one to build?? [Re: dodgefarmer] #113369
09/02/08 10:58 AM
09/02/08 10:58 AM
dogdays Offline
dogdays  Offline
They're a substitute head for the 906s. They have all the problems of the 906 and any other big block open chamber head. Out-of-the-box flow is less than 230 cfm, port stalls somewhere between 0.400 and 0.450 lift, the open chamber is 88-92 cc and has NO squish, the spark plug is in the wrong place, all in all it's amazing they ran as good as they did. The 915 head has a better chamber. The Edelbrock and 440Source heads have the 915 chamber or close and flow at least 30 cfm more, making them an easy choice.
R.
Re: 440 head is it a good one to build?? [Re: ta70mopar] #113370
09/02/08 12:15 PM
09/02/08 12:15 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Street car? Street/ strip? What's the car?
Stock heads for a street car should cost
under $700 with all new parts and rebuild.
Spend any more, then I would just go with
Eddie RPMs or the 440 Stealth's.
Snap your neck, mega G-force launch, is all I want!
Re: 440 head is it a good one to build?? [Re: BDS871Cuda] #113371
09/02/08 05:01 PM
09/02/08 05:01 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
I'm running reworked 516 heads and I like 'em.
'71 SSP - SOLD!
