440 head is it a good one to build??
#113361
09/01/08 02:09 AM
09/01/08 02:09 AM
Posts: 16 Wa,Whatcom
ta70mopar
Wa,Whatcom
Cast number 2951250 is that a good head to build? Just picked up a 383 and it has these heads on it. What I have found it is a 68 440. Is that a good head for a 383. thanks Also is that a closed or opened chamber
Re: 440 head is it a good one to build??
[Re: GODSCOUNTRY340]
#113363
09/01/08 10:58 AM
09/01/08 10:58 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Depends what they need.Usually you will have more in them than a good set of new aluminum will cost.Rocky
Chrysler Firepower
[Re: therocks]
#113364
09/01/08 11:05 AM
09/01/08 11:05 AM
RapidRobert
I would search for a set of reasonably priced 915's for the closed chambers or spring for aluminum ones again for the very desireable closed chamber & with pistons to match to get proper quench.
[Re: ta70mopar]
#113366
09/01/08 02:33 PM
09/01/08 02:33 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
It depends a lot on what your goals are. You will find that most comparison test info, shows that almost all the open chambered oem heads perform about the same if ported by the same guy. If it's a cruiser car, thaose are more than good enough.
[Re: dave571]
#113367
09/01/08 02:35 PM
09/01/08 02:35 PM
DaytonaTurbo
Manitoba, Canada
Yeah, if you just want a rebuilt stock head, they're fine. If you want porting, big valves, etc, then I suggest you take a look at some aftermarket heads. For the $ you have to put into cast iron heads, aluminums might not be much more $.
