making round tube to rectangle in header flanges #1133456
12/13/11 07:47 PM
12/13/11 07:47 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
So I remeber a post long ago I think it was here about some tricks to doing this quickly. I am building my uncle a set of headers for a 440 in his car. I am thinking of using a deadblow and flatining (sp) out the tubes till they fit then tack weld them then hammer them to fit on the inside. Does this sound about right?
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: making round tube to rectangle in header flanges [Re: haddixj] #1133457
12/13/11 08:47 PM
12/13/11 08:47 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Yep
Re: making round tube to rectangle in header flanges [Re: JD Dart] #1133458
12/13/11 09:01 PM
12/13/11 09:01 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Heres what I did, gently knocking in
to round tube, tapping the sides with a flat body hammer to flatten as you go. Takes about two minutes to square a tube up to flange hole.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: making round tube to rectangle in header flanges [Re: 23T Hemmee] #1133459
12/13/11 09:03 PM
12/13/11 09:03 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Another pic
Ronny
John 14:6
Re: making round tube to rectangle in header flanges [Re: 23T Hemmee] #1133460
12/13/11 10:07 PM
12/13/11 10:07 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
seen it done pretty simple
take some flat stock cut a hole same size your hedder flange is take your tube tap in the sides enuff to get to fit in the square hole slide tube into the square drice a tappered wedge (pyrmid) inside the tube
makes a perfict fit
least to the jig you made
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: making round tube to rectangle in header flanges [Re: haddixj] #1133461
12/13/11 10:22 PM
12/13/11 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I make a plug the size of the flange opening with a
tapered lead on it ... I weld that to a solid rod
(about 3/4 to 1") then drive that into the pipe
and tap the tubing to fit OR... this is the way I
did it at work.. same tapered plug then weld it to
1" fine thread bolt, then screw that into the flaring
section of our Huth tube bender and ram the plug
in... I could have all 8 done in 5 minutes... so
if you got a exhaust shop near you do what I said
and take you plug and tube to them only a few bucks
(also lube the plug with grease so it slides easy)
