2264598 flywheel application #1133195
12/13/11 08:38 AM
12/13/11 08:38 AM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
I know this number carries over a number of different engines and crank types, but what is the exact application of this one? thanks in advance
Re: 2264598 flywheel application [Re: Desmond] #1133196
12/13/11 08:39 AM
12/13/11 08:39 AM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
another
Re: 2264598 flywheel application [Re: Desmond] #1133197
12/13/11 08:40 AM
12/13/11 08:40 AM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
another pic
Re: 2264598 flywheel application [Re: Desmond] #1133198
12/13/11 08:41 AM
12/13/11 08:41 AM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
last one
Re: 2264598 flywheel application [Re: Desmond] #1133199
12/14/11 04:38 PM
12/14/11 04:38 PM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
Re: 2264598 flywheel application [Re: Desmond] #1133200
12/14/11 06:36 PM
12/14/11 06:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The casting number is just that, a casting number and it would be on all flywheels no matter what engine it bolted to. What makes that one unique is the 2 scalloped cuts, that came off an external balanced engine. Which one ????
Re: 2264598 flywheel application [Re: JohnRR] #1133201
12/14/11 09:40 PM
12/14/11 09:40 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Ya never seen one with 2 cuts. 400 4-spd has one cut and not as deep.
Is it a 130 tooth?
Maybe 71 383 cast crank w/ 3-spd?
Galen's book show the same casting number for 130 and 143 tooth.??
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 2264598 flywheel application [Re: moparmarks] #1133202
12/15/11 11:47 AM
12/15/11 11:47 AM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
130 teeth
Re: 2264598 flywheel application [Re: Desmond] #1133203
12/15/11 03:24 PM
12/15/11 03:24 PM
CANADA
Desmond Offline OP
Desmond  Offline OP
CANADA
according to the imprint left by the crank it had a notch in it...
Re: 2264598 flywheel application [Re: Desmond] #1133204
12/15/11 03:28 PM
12/15/11 03:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
130 teeth
nothing was external balance that I know of before 1970 so it would be either a 440-6pk , a 360 , cast crank 340 , cast crank 383-2bbl , cast crank 440 , or a 400 ...
Re: 2264598 flywheel application [Re: Desmond] #1133205
12/15/11 05:51 PM
12/15/11 05:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think the only way you can tell what it's for is to compare it to another with a known origin. The flywheels with the drilled external balance holes are easier to ID than the ones with the scallop cuts.
The heaviest external balance is the LA 360, next down is the cast crank BB but, since the cast crank BB's didn't generally get stick shifts, there's a good chance that flywheel is from a LA360.
Re: 2264598 flywheel application [Re: John_Kunkel] #1133206
12/17/11 11:28 AM
12/17/11 11:28 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
70- 71 440 hp 4bbl or 4406bbl one
Re: 2264598 flywheel application [Re: 440beep] #1133207
12/17/11 11:30 AM
12/17/11 11:30 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 2264598 flywheel application [Re: 440beep] #1133208
12/17/11 02:42 PM
12/17/11 02:42 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Is the flywheel in this photo a 1970 440-4 or 440-6 flywheel? If so, what is the key ID factor?
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 2264598 flywheel application [Re: 70gtx440dana] #1133209
12/17/11 08:45 PM
12/17/11 08:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In '70 the 440-4 and the 440-6 used the same flywheel, the one in the last pic looks correct for that.
Re: 2264598 flywheel application [Re: John_Kunkel] #1133210
12/17/11 11:24 PM
12/17/11 11:24 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
71 is the same one
Re: 2264598 flywheel application [Re: John_Kunkel] #1133211
01/20/14 11:34 PM
01/20/14 11:34 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I'm confused...how can the external balanced 440-6 fly wheel be the same as an internal balanced 440? Is it all in the harmonic balancer?
Re: 2264598 flywheel application [Re: Quicksilver440] #1133212
01/21/14 01:21 AM
01/21/14 01:21 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe the poster is referring to a Big Connecting Rod 440, or HP 440 in 1970.
1971 HEMI E BODY REGISTRY
