Re: 2264598 flywheel application
[Re: Desmond]
#1133196
12/13/11 08:39 AM
12/13/11 08:39 AM
Posts: 1,106 CANADA
Desmond
CANADA
[Re: Desmond]
#1133197
12/13/11 08:40 AM
12/13/11 08:40 AM
Posts: 1,106 CANADA
Desmond
CANADA
[Re: Desmond]
#1133198
12/13/11 08:41 AM
12/13/11 08:41 AM
Posts: 1,106 CANADA
Desmond
CANADA
[Re: Desmond]
#1133199
12/14/11 04:38 PM
12/14/11 04:38 PM
Posts: 1,106 CANADA
Desmond
CANADA
[Re: JohnRR]
#1133201
12/14/11 09:40 PM
12/14/11 09:40 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Ya never seen one with 2 cuts. 400 4-spd has one cut and not as deep. Is it a 130 tooth? Maybe 71 383 cast crank w/ 3-spd? Galen's book show the same casting number for 130 and 143 tooth.??
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1133202
12/15/11 11:47 AM
12/15/11 11:47 AM
Posts: 1,106 CANADA
Desmond
CANADA
[Re: Desmond]
#1133204
12/15/11 03:28 PM
12/15/11 03:28 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
130 teeth
nothing was external balance that I know of before 1970 so it would be either a 440-6pk , a 360 , cast crank 340 , cast crank 383-2bbl , cast crank 440 , or a 400 ...
[Re: Desmond]
#1133205
12/15/11 05:51 PM
12/15/11 05:51 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think the only way you can tell what it's for is to compare it to another with a known origin. The flywheels with the drilled external balance holes are easier to ID than the ones with the scallop cuts.
The heaviest external balance is the LA 360, next down is the cast crank BB but, since the cast crank BB's didn't generally get stick shifts, there's a good chance that flywheel is from a LA360.
[Re: 70gtx440dana]
#1133209
12/17/11 08:45 PM
12/17/11 08:45 PM
John_Kunkel
Rio Linda, CA
In '70 the 440-4 and the 440-6 used the same flywheel, the one in the last pic looks correct for that.
[Re: John_Kunkel]
#1133211
01/20/14 11:34 PM
01/20/14 11:34 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I'm confused...how can the external balanced 440-6 fly wheel be the same as an internal balanced 440? Is it all in the harmonic balancer?
