Holley fast idle cam? #1131927
12/11/11 07:47 PM
12/11/11 07:47 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
I have never gotten along with Holleys so haven't played much with them but now the newest addition to the fleet has one of the danged things on it and of course it has an issue. The fast idle cam/lever behind the choke (electric) housing does not drop down/forward so the engine can't come off fast idle. I've removed the choke and everything on the rear of the housing seems to operate freely including the fast idle cam, but it's free floating and I'm wondering if that's correct. By free floating I mean there's no springs or other device to cause it to fall (off fast idle), it appears that gravity is the only force at work. Is this correct? If it's right, then what can be done to cause it to rotate/fall to allow the engine to idle down?? Other than this it actually seems to run pretty well so I'd rather not change carbs just to get to the type I know.
Mike
Re: Holley fast idle cam? [Re: 1E2C] #1131928
12/11/11 08:33 PM
12/11/11 08:33 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
spray it with carb cleaner to remove any residue and it should free fall from its own weight !
Re: Holley fast idle cam? [Re: calrobb2000] #1131929
12/11/11 09:13 PM
12/11/11 09:13 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
That was my plan, but wanted to check in before I reassembled it since it is just plastic and really doesn't have any weight to it at all.
Thanks,
Mike
Re: Holley fast idle cam? [Re: 1E2C] #1131930
12/12/11 12:13 AM
12/12/11 12:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks,
Mike
The choke itself has a bi-metal spring to close the
choke blade and via linkage it lifts the plastic choke
cam... as the bi-metal warms it allows the blade
to open... it can be full open but it wont come off
the fast idle cam UNTILL you touch the thottle...
at that point it should drop... clean it good to make
sure theres nothing binding on the shaft to the plastic...
if it drops and it doesnt idle back down the fast idle
screw could be in way to far
Re: Holley fast idle cam? [Re: MR_P_BODY] #1131931
12/12/11 12:54 AM
12/12/11 12:54 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Yeah, the choke itself seemed to be working fine, the butterflies opened as it warmed but the fast idle cam wouldn't drop without me pressing it down. There's only about 1/16" of screw protruding from the tab on the lever so it shouldn't be too far in I wouldn't think. Now that I cleaned everything up though, it doesn't want to go back on correctly - something is binding and the whole thing is balled up. Gave up for tonight, probably won't mess with it until next weekend now.
Mike
Re: Holley fast idle cam? [Re: 1E2C] #1131932
12/12/11 12:55 AM
12/12/11 12:55 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Linkage
Re: Holley fast idle cam? [Re: 1E2C] #1131933
12/12/11 01:01 AM
12/12/11 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just make sure its all clean and free... linkage also
