'71 Charger Taillight Harness
#1131634
12/11/11 11:47 AM
12/11/11 11:47 AM
Posts: 2,016 Frederick, MD
71charger
Frederick, MD
I need new sockets for my taillights but can't find a harness for a '71. Year One sells their RL74 harness for '72 to '73, can I use the later harness in my '71?
Re: '71 Charger Taillight Harness
[Re: 71charger]
#1131635
12/11/11 12:43 PM
12/11/11 12:43 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
before you give up on the existing sockets, I refurbished my 72 taillights which the bulbs were corroded in by busting the bulbs out and prying and pulling out the brass remains. Then cleaning any remains of the bulb out. I then dumped in a liquid rust remover/dissolver into the bulb socket. Much to my surprise the sockets hold the liquid in and the rust dissolver will take out the corrosion and re-plated them. Do this a couple of times and start working the springs to break corrosion off them. Mine work perfect now. But this may not be your situation but if it is thought I would give you something to think about.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: 71charger]
#1131636
12/11/11 02:00 PM
12/11/11 02:00 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
..........I have the same prob with my 71 R/T . Nobody make replacement harness for them , not even Mopar. The sockets are not removable from the besels like some of the other years. In my case I just cleaned them up the best I could. Im wonderin if M&H could replace the sockets ?
[Re: 71charger]
#1131639
12/11/11 05:50 PM
12/11/11 05:50 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
some details on this...
first, 71 used two diff tail lights setup, same as 72s, so WHICH ONE IS THE ONE THEY SELL ?
second, 73 and 74 used both SAME tail lights, so how somebody can offer a 72/73 without include 74 ?
3rd, Rallye tail lights are without a ground wire due the housing is pot metal, taking ground from chassis... same as 72 standard. Dunno 71 standards, so more reasons to be diff
4th, as far I know 71/72 standards are integrated sockets ( pressed into ) to the housing, like 73/74 but these lates being plastic housing, not removable like Rallyes tail lights... this is the diff I'm saying on 1st point
so, where is the truth ?
[Re: 71charger]
#1131641
12/11/11 11:15 PM
12/11/11 11:15 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
It has been a while but I recall buying some after market sockets and making mine work. I put '71 tail lights in my '72 so I was not worried about originality but no one can see any difference. They look like they came from the factory. The harness I got from an R/T donor was not in the best shape. Here is a link to look at.. http://www.qualitydist.net/pico-5469pt.html
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: 71charger]
#1131643
12/12/11 01:09 PM
12/12/11 01:09 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Please be sure to let us know how it works out.
I have a set of R/T tail lights I need to replace all the sockets and wiring on as well so I'll be anxious to hear the final results.
[Re: 71charger]
#1131647
12/22/11 02:19 PM
12/22/11 02:19 PM
Posts: 434 DELAWARE
bee71mopar
DELAWARE
Sadly, the '72 harness arrived from Year One and it looks nothing like the photo on the website. It has no light sockets. I guess I'll hit the auto parts, buy a few sockets and repair what I have.
Try these guys and send the correct one in and he can make you one.Just a thought. http://evanswiring.com/
