Just how bad is..... ***updated*** #1130943
12/10/11 02:52 AM
12/10/11 02:52 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
.009 to .010 piston to wall clearance??
Is it bad enough to scrap the pistons and buy new ones? or will this just be an inconvenience, noisy build that wont last too long?
I just found out my piston to wall clearance is not very good on my 451 cid, 4.375 bore B1 build, which means if I need new pistons, it will push me over my budget as these are not some off the shelf pistons..
What do you think?
Re: Just how bad is..... [Re: Jeepmon] #1130944
12/10/11 02:56 AM
12/10/11 02:56 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Sounds great! I assume this is not a 100,000 mile street build?
Re: Just how bad is..... [Re: goldmember] #1130945
12/10/11 02:57 AM
12/10/11 02:57 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Yep.. race only!!
Re: Just how bad is..... [Re: Jeepmon] #1130946
12/10/11 03:15 AM
12/10/11 03:15 AM
Arizona
Chris'sBarracuda Offline
Arizona
Do you have the piston job number.?
Chris..
Re: Just how bad is..... [Re: Jeepmon] #1130947
12/10/11 03:19 AM
12/10/11 03:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine are only around .007 but Jason Pettis likes to run em a bit looser than manufacture recommendations but .010 on modern piston sounds a bit loose but what do I know............
Re: Just how bad is..... [Re: Chris'sBarracuda] #1130948
12/10/11 03:20 AM
12/10/11 03:20 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Chris..
The pistons are at the machine shop now, so a call on Monday might answer your question.. But I dont recall seeing a part number or job number on there.. The only number I saw was a forging number..
Re: Just how bad is..... [Re: Thumperdart] #1130949
12/10/11 03:23 AM
12/10/11 03:23 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
There has been several that have recommended coating the pistons with a coating that will take up approx .002.. I do know thats an option..
(and from what I hear.. Pettis is the man!!)
Re: Just how bad is..... [Re: Jeepmon] #1130950
12/10/11 03:24 AM
12/10/11 03:24 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s definately an option.............
Re: Just how bad is..... [Re: Jeepmon] #1130951
12/10/11 03:30 AM
12/10/11 03:30 AM
Arizona
Arizona
Chris..
If you know the manufacturer, call them and ask.
When I was assembling mine I thought there was too much clearance, (.010)..
But when I talked to Tom Prock @ Venolia he said that with my piston that .0085-.011 was the tolerance..
So there you have it..
:EDIT: This is for a 4.505 bore B1 Venolia 1.29 CD .043 x.043 x 3/16
Chris..
Re: Just how bad is..... [Re: Chris'sBarracuda] #1130952
12/10/11 03:37 AM
12/10/11 03:37 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Chris..
Just learned something new......AGAIN.
Re: Just how bad is..... [Re: Chris'sBarracuda] #1130953
12/10/11 04:17 PM
12/10/11 04:17 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Chris..
Thats interesting Chris.. I've done quite a bit of reading last night and it seems that the majority of the engine builders strive for no more than .007... This is why I posted my question..
BTW.. These are JE Pistons and I will be calling the machine shop on Monday to see if the pistons are engraved..
Re: Just how bad is..... [Re: Jeepmon] #1130954
12/10/11 05:02 PM
12/10/11 05:02 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I agree... call the maker with the job# for piston ID. The builder may be measuring the skirts in the wrong place and/or that may be the design intent of the maker. Or you may want to coat the skirts.
Re: Just how bad is..... [Re: Jeepmon] #1130955
12/10/11 05:09 PM
12/10/11 05:09 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i had my diamond skirts coated, don't know the thickness. $120.00 to do the skirts. as mentioned, that maybe a good option for u. good luck, seeya.
Re: Just how bad is..... [Re: Jeepmon] #1130956
12/11/11 02:38 PM
12/11/11 02:38 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Yes you need new pistons. That is way too much clearence. The pistons will rock too much causing the rings not to ride square in the bore and the ring seal will be horrible. We run .004 in my small block.
Steve
Re: Just how bad is..... [Re: Jeepmon] #1130957
12/11/11 03:23 PM
12/11/11 03:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
Don, the piston clearances are determined by several things, the piston alloy being the main one Get the job number off of the pistons and call them(JE) to get thier recommendations If they need coating try calling Embee CO., 714-546-6907, to see if they will hard anadyse(SP?) your pistons. I had them do a set several years back to restore the skirts on a set of Ross pistons that where in a motor that the lifters tops failed and the debris hurt the clinder walls and piston skirts. That was a long time ago and the owner has squeezed(sprayed NOS) that motor a lot since then and beat the snout out of it on the street for close to 20,000 miles on pump gas and accoding to him the pistons look like new the last time he looked at them EDITED: I forgot to mention that Embee is a goverment certified aircraft parts maker and repair center, good stuff Make sure you tell them, if you decide to use them,that you want the hard anadising coating, just like the top fuelers use
Re: Just how bad is..... [Re: Cab_Burge] #1130958
12/11/11 04:53 PM
12/11/11 04:53 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Are the pistons or the bores out of spec?
Don't know what you have invested in the block but it may be more cost effective to find another.
Re: Just how bad is..... [Re: AAR-B4] #1130959
12/11/11 08:39 PM
12/11/11 08:39 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Definetly find out what the piston manufactor specs are. Some pistons call for much more then others depending on the piston material and make but .010 is a good bit. Ron
Re: Just how bad is..... [Re: 383man] #1130960
12/11/11 09:20 PM
12/11/11 09:20 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
i didnt see anyone ask were it loose at.. is it taper? meaning the top of the cylinder has more wear/taper than the bottom..
Like engines with lots of miles?
If its consistent, you could use little bigger bore ring, say .005 or so.. if it's taper it wont matter much... It will run sure... It might slobber and have excess blow by...
Re: Just how bad is..... [Re: Bob_Coomer] #1130961
12/12/11 02:11 PM
12/12/11 02:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think you know my answer
Re: Just how bad is..... [Re: Al_Alguire] #1130962
12/13/11 08:21 PM
12/13/11 08:21 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Spoke with JE Pistons.. the pistons I have are old as they have no engraving on them.. and also, JE would like to see a max clearance of .0045..
So it looks like I will be shopping for new pistons..
Thanks to everyone for their assistance
