E Body with Hotckis suspension: which shocks to buy? #1130654
12/09/11 07:34 PM
12/09/11 07:34 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have a complete Hotchkis suspension system for an E Body Im building.
I do not have the shocks yet.
I see these Bilsteins on the Hotchkis website:
http://www.hotchkis.net/rcd_shocks_dodge_a_e_body_4_pack_stock_height_cars.html
Should I get these, or are there any better choices out there?
Or a choice that gets you more bang for the buck?
Re: E Body with Hotckis suspension: which shocks to buy? [Re: domingo] #1130655
12/09/11 07:37 PM
12/09/11 07:37 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
From what I have heard on this site whenever people buy the TVS and the Blistens is that they absolutely love the ride. Some people have also just bought the Blistens by themselves and said it greatly improved their handling. Let's wait for more people to chime in.
Re: E Body with Hotckis suspension: which shocks to buy? [Re: MuuMuu101] #1130656
12/09/11 08:55 PM
12/09/11 08:55 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The Bilsteins are a great shock...
A step better than the Konis...
Just my $0.02..
Re: E Body with Hotckis suspension: which shocks to buy? [Re: domingo] #1130657
12/10/11 02:37 AM
12/10/11 02:37 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Not really a better choice for bang for the buck.
What is your intentions for the vehicle?
If you want to make it an ultimate dedicated full time track car, you can spend $4K on a set of shocks and then go UP from there. But you will have to have the rest of the vehicle up to that level to take advantage of them.
Re: E Body with Hotckis suspension: which shocks to buy? [Re: autoxcuda] #1130658
12/10/11 04:22 AM
12/10/11 04:22 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Umm, ask Hotckis(sp)? They should know I hope. Hope they chime in.
-Daty
Re: E Body with Hotckis suspension: which shocks to buy? [Re: autoxcuda] #1130659
12/10/11 11:54 AM
12/10/11 11:54 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I guess you are right, Ill just get wat they reccomend. Yes, everything is done to that level...,makes sense.
Re: E Body with Hotckis suspension: which shocks to buy? [Re: domingo] #1130660
12/10/11 12:31 PM
12/10/11 12:31 PM
So Cal
So Cal
To what level? Do you just have a TVS System?
$4K+ shocks would be on an racecar or almost racecar with full rollcage, race tires, etc etc.
Re: E Body with Hotckis suspension: which shocks to buy? [Re: autoxcuda] #1130661
12/10/11 12:44 PM
12/10/11 12:44 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, I meant the the TVS system. All is done to that level.
I went a bit further and added through the floor connectors, I also replaced the rocker panels with thicker gauge fabricated rockers, I also braced the front clip from behind the inner fenders (kinda like the things XV sells but a bit more robust and better tied). My connectors go through the trans crossmember and onto the front clip. I also added a lower radiator reinforcement with square tubing. I have also added extra spot weld throughut the body.
I will weld the K frame shut.
Also, I will install a firm feel stage 3 box.
I wanted to keep the car looking "stock".
Ill post some pics...
Re: E Body with Hotckis suspension: which shocks to buy? [Re: domingo] #1130662
12/10/11 12:55 PM
12/10/11 12:55 PM
So Cal
So Cal
For that the Bilsteins are a good match.
What size torsion bars?
What size front a rear tires?
What motor?
Re: E Body with Hotckis suspension: which shocks to buy? [Re: domingo] #1130663
12/10/11 01:23 PM
12/10/11 01:23 PM
Finland
CarelianCuda Offline
Finland
I have RCD Bilsteins from Hotchkis, but shorter ones on front and stock length on rear.
I'm happy but i can't really compare to anything exept the old ones.
You don't need those tall ones if you don't have a raised vehicle.
Lifted from K-member for the pic, seems long enough? Tires are 235/60/15 and sorry for crappy pic.
1970PlymouthCuda383
1970AMCHornet2D232
2003TruckmastersOkenosDurangoSlt+
2008DodgeChallengerSRT8
Re: E Body with Hotckis suspension: which shocks to buy? [Re: CarelianCuda] #1130664
12/14/11 03:12 AM
12/14/11 03:12 AM
Sante Fe Springs, CA
Hotchkis Offline
Hotchkis  Offline
Hey all,
Thanks for the nice words and support about Hotchkis products and the Bilstein shocks we offer for stock and lowered height Mopars. These specific shocks are very well-engineered and work great in the optimum compression and rebound range for the application. So you can’t go wrong with getting shocks we’ve confirmed and matched to our TVS kit. We have more autocross wins than any other early Mopar suspension aftermarket suspension company, so they’re not only suggested…they’re proven!
Re: E Body with Hotckis suspension: which shocks to buy? [Re: Hotchkis] #1130665
12/14/11 07:39 PM
12/14/11 07:39 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Considering how tip-everyone-out-the-windows my car is with brand-new Monroes, I don't doubt these would improve a stock suspension, too...
Re: E Body with Hotckis suspension: which shocks to buy? [Re: Secret Chimp] #1130666
12/15/11 12:11 PM
12/15/11 12:11 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I had the Yellow monroes on a Challenger and I always felt that the ride was too harsh....but oh well, we do have bad roads down here. On the highway it felt fine, but I never did some serious handling tests to the car....it was all stock suspension otherwise.
I can say with all the stock suspension I did find the ride with the stock style shocks a LOT nicer and enjoyable. Cruising mode of course.
