'70 Charger RT engine/trans stampings #1129712
12/08/11 01:01 AM
12/08/11 01:01 AM
NY
70440+6bbl Offline OP
NY
I think the car is legit, but the engine # is very odd... They are in an unrestored car and the fellow just cleaned the pads off to check the #'s for me.
Re: '70 Charger RT engine/trans stampings [Re: 70440+6bbl] #1129713
12/08/11 02:13 AM
12/08/11 02:13 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Looks OK to me.....Ma Mopar was not always nice and neat with these type of operations. My transmission is hardly legible in comparison to this one.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: '70 Charger RT engine/trans stampings [Re: 70gtx440dana] #1129714
12/08/11 03:19 AM
12/08/11 03:19 AM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
They look good but boy the stamp set shifted from engine to transmission stamping!
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: '70 Charger RT engine/trans stampings [Re: 70440+6bbl] #1129715
12/08/11 09:21 AM
12/08/11 09:21 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Man... Did that Charger participate in the MUD RUN 500 before it was parked? Looks like the block is caked with mud..
Good luck..
Troy
Houston Mopar Connection Club
Re: '70 Charger RT engine/trans stampings [Re: hemi68charger] #1129716
12/08/11 10:40 AM
12/08/11 10:40 AM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
Yup, I'd say if it's even and legible, it's a FAKE!
The stamping on my 69 RT/SE is a double stamp and looks like the "Shaker" stickers under the 70's E-Bodys hood. My eyes hurt looking at it. Good find!
Cheers
Re: '70 Charger RT engine/trans stampings [Re: 68RRFlyer] #1129717
12/08/11 11:53 AM
12/08/11 11:53 AM
NY
NY
Usually, I find that the eng/trans stampings match each other. This one isn't even close. I have have seen plenty of double strikes also.
Re: '70 Charger RT engine/trans stampings [Re: 70440+6bbl] #1129718
12/08/11 02:09 PM
12/08/11 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Need better/bigger pictures. Since the engine and trans were stamped at the same time they SHOULD match.
Re: '70 Charger RT engine/trans stampings [Re: JohnRR] #1129719
12/08/11 05:36 PM
12/08/11 05:36 PM
NY
NY
John, the car is on e-bay right now. I was interested until I had him check the upper support #'s and he couldn't find any (first tip off was the 22" radiator). So, the car took a shot in the front at one time and whatever shop worked on the car, replaced the rad suppot with one from a 22" car.
Re: '70 Charger RT engine/trans stampings [Re: 70440+6bbl] #1129720
12/08/11 05:41 PM
12/08/11 05:41 PM
NY
NY
Here is the trans stmaping on a St.Louis '71 GTX I used to own. The #'s were also stamped on an angle. Non-original engine in that car, so no idea if they were stamped the same.
Re: '70 Charger RT engine/trans stampings [Re: 70440+6bbl] #1129721
12/08/11 06:14 PM
12/08/11 06:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The engine are trans are stamped after they are assembled together ,before installation in the body, by the same person using the same tool , unless the tool breaks for some odd reason in between going from one item to the other ????
Re: '70 Charger RT engine/trans stampings [Re: JohnRR] #1129722
12/08/11 08:41 PM
12/08/11 08:41 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
What is the casting and assembly date on the block.
The trans looks okay. I need to see a larger and clear photo of the engine pad. The engine stamp is not the norm. It is odd but needs further review.
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: '70 Charger RT engine/trans stampings [Re: 70440+6bbl] #1129723
12/08/11 10:18 PM
12/08/11 10:18 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I took the 3 pics on the ebay listing and arranged them close together, thinking it might help for comparison. It may or may not.
Re: '70 Charger RT engine/trans stampings [Re: moparfan53] #1129724
12/08/11 10:29 PM
12/08/11 10:29 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Without seeing it in person it is very difficult to say. However, I'm leaning toward it beign the real deal stamp. The broach marks are in place and the font size and style appears to be correct. It would be good to see the engine assembly information and casting date.
Was the VIN ever found on the LH rear deck lid seal lip?
Re: '70 Charger RT engine/trans stampings [Re: JohnRR] #1129725
12/08/11 10:35 PM
12/08/11 10:35 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
I agree most of the time. However, there are exceptions. Here is a perfect stamp match as described.
Re: '70 Charger RT engine/trans stampings [Re: MMC Detroit] #1129726
12/08/11 10:43 PM
12/08/11 10:43 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
They have mixed letters and numbers. There are O's in place of 0's. The 1's are upside down on the block. These are two stamps are different. In my opinion the block is the fake.
Re: '70 Charger RT engine/trans stampings [Re: convx4] #1129727
12/08/11 10:53 PM
12/08/11 10:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Not an original stamping on the block. Ask him for the casting & engine assembly dates also just for fun.
Re: '70 Charger RT engine/trans stampings [Re: convx4] #1129728
12/08/11 10:56 PM
12/08/11 10:56 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
I noticed the same details and do not disagree. Something happended between the eng and trans stamp process. But I have seen strange variations on real cars. There are many more details that have to be checked out to be 100% sure.
Re: '70 Charger RT engine/trans stampings [Re: MMC Detroit] #1129729
12/08/11 10:58 PM
12/08/11 10:58 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
That trans stamp is the real deal, but that motor sure IS NOT. It's way too sloppy, both #1's are UPSIDE DOWN,and the "0" is actually an "O". I do see the broach marks which are legit, which leads me to believe the block was a replacement block that origianlly was BLANK. The casting date will tell more.
Re: '70 Charger RT engine/trans stampings [Re: convx4] #1129730
12/08/11 11:12 PM
12/08/11 11:12 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
The two 8's are different in style... the top circle is smaller on the block compared to the trans.
Re: '70 Charger RT engine/trans stampings [Re: rayztoy] #1129731
12/09/11 01:33 AM
12/09/11 01:33 AM
NY
NY
I don't know, I am starting to really think it is legit... If it was a warranty/blank pad, it would not have the top id pad stamped with the assembly date like this. I have seen plenty of restamps, usually they are way to neat (but, wrong font and lack the broaching marks,etc). I don't think anyone would go through the trouble of restamping a block and then intentionally put the numeral 1's upside down... What if the gang holder fell on the floor and the guy stamping the block just through it back together quickly with the letters and #'s all jumbled up?
