Re: '70 Charger RT engine/trans stampings
[Re: 70440+6bbl]
#1129713
12/08/11 02:13 AM
12/08/11 02:13 AM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
Looks OK to me.....Ma Mopar was not always nice and neat with these type of operations. My transmission is hardly legible in comparison to this one.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#1129714
12/08/11 03:19 AM
12/08/11 03:19 AM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
They look good but boy the stamp set shifted from engine to transmission stamping!
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
[Re: 70440+6bbl]
#1129715
12/08/11 09:21 AM
12/08/11 09:21 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Man... Did that Charger participate in the MUD RUN 500 before it was parked? Looks like the block is caked with mud..
Good luck..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: 70440+6bbl]
#1129721
12/08/11 06:14 PM
12/08/11 06:14 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Here is the trans stmaping on a St.Louis '71 GTX I used to own. The #'s were also stamped on an angle. Non-original engine in that car, so no idea if they were stamped the same.
The engine are trans are stamped after they are assembled together ,before installation in the body, by the same person using the same tool , unless the tool breaks for some odd reason in between going from one item to the other ????
[Re: JohnRR]
#1129722
12/08/11 08:41 PM
12/08/11 08:41 PM
Posts: 974 www.mmcdetroit.com
MMC Detroit
www.mmcdetroit.com
What is the casting and assembly date on the block.
The trans looks okay. I need to see a larger and clear photo of the engine pad. The engine stamp is not the norm. It is odd but needs further review.
MMC/ ICCA Detroit.
The Motor City or where ever there is Mopars
[Re: moparfan53]
#1129724
12/08/11 10:29 PM
12/08/11 10:29 PM
MMC Detroit
www.mmcdetroit.com
Without seeing it in person it is very difficult to say. However, I'm leaning toward it beign the real deal stamp. The broach marks are in place and the font size and style appears to be correct. It would be good to see the engine assembly information and casting date.
Was the VIN ever found on the LH rear deck lid seal lip?
MMC/ ICCA Detroit.
[Re: convx4]
#1129730
12/08/11 11:12 PM
12/08/11 11:12 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
They have mixed letters and numbers. There are O's in place of 0's. The 1's are upside down on the block. These are two stamps are different.
The two 8's are different in style... the top circle is smaller on the block compared to the trans.
