Driving technique help! #1129623
12/07/11 07:46 PM
12/07/11 07:46 PM
Penna
70satelliteguy Offline OP
Penna
Last year I developed a bad habit of turning the wheel some(usually to the left) when letting go of the transbrake button. This causes me to have to correct when the wheels touch down. I usually hold the steering wheel at about 11-12 oclock as this is where it is most comfortable for me.
I tried putting some tape around the steering wheel at the top like Jeggie does and holding the wheel at 3 0clock to try and minimize movement but I still have the problem. I don't do it every time but I want to try and eliminate the problem completely.
Has anyone else had this problem and found an easy way to cure it?
Thanks Mike
Re: Driving technique help! [Re: 70satelliteguy] #1129624
12/07/11 08:00 PM
12/07/11 08:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I steer with my left hand... I put my elbow/arm on
the lower edge of the window on the door
Re: Driving technique help! [Re: MR_P_BODY] #1129625
12/07/11 08:10 PM
12/07/11 08:10 PM
Penna
Penna
Thanks for the reply Mr. P body!
That would seem to help but I will have to check if that would work with a B body. It would be a little further away than in a smaller car such as yours.
Thanks Mike
Re: Driving technique help! [Re: 70satelliteguy] #1129626
12/07/11 08:46 PM
12/07/11 08:46 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I also use my left hand and used to drive with it at the 12 o clock position and was advised to change to around 9 o clock when I started bringinmg the front wheels up.
I try to brace my elbow in against the roll bar and the bottom bar of my window net to keep it from moving when I luanch.
Re: Driving technique help! [Re: WILD BILL] #1129627
12/08/11 03:16 AM
12/08/11 03:16 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
You might try to make sure you are firmly against the seat back before launching the car. If you are using the wheel to prevent smacking your head on the seat, you may be inadvertly turning the wheel slightly. AMHIK
Also, it may prevent a headache or two.
Beep
Re: Driving technique help! [Re: Bigbeep] #1129628
12/08/11 09:23 AM
12/08/11 09:23 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
is your trans-brake button on your wheel?
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Driving technique help! [Re: StripeHOG] #1129629
12/08/11 09:50 AM
12/08/11 09:50 AM
Penna
Penna
Yes my transbrake button is on my steering wheel. It is on the right side. I release the button and go for the shifter. For some reason I end up turning the wheel a little downward(steering the car to the left). I think it is similar to when I am going down the road in my car and I look at something off to one side or the other. I always seem to steer in the opposite direction.
Mike
Re: Driving technique help! [Re: 70satelliteguy] #1129630
12/08/11 12:34 PM
12/08/11 12:34 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
dont grip the wheel with your right hand, just use your thumb on the button, practice at home, plus your reaction time will pick up. it worked for me. left hand 10:00
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Driving technique help! [Re: 440lebaron] #1129631
12/08/11 02:21 PM
12/08/11 02:21 PM
Penna
Penna
440lebaron maybe I have you confused .I don't grab the steering wheel with my right hand. I do just push the button with my right hand and steer with my left hand. I have tried holding the wheel as close to 6 o'clock as possible to limit how much I am able to move my left arm but it does not feel comfortable to me and I don't feel as though I have as much controll to correct from that grasping point!
Mike
Re: Driving technique help! [Re: 70satelliteguy] #1129632
12/08/11 02:29 PM
12/08/11 02:29 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
you may be moving the wheel unconsciously when you take your right hand off of the button. DO it at home and have someone watch you to see what you are doing, then make adjustments to your style.
Re: Driving technique help! [Re: Dodgeguy101] #1129633
12/08/11 08:05 PM
12/08/11 08:05 PM
farmingdale ny 11735
blracing Offline
blracing  Offline
take the trans brake button off the wheel! make a mount for it off the dash or off the shifter and see how you do.
Re: Driving technique help! [Re: blracing] #1129634
12/09/11 10:14 AM
12/09/11 10:14 AM
tboomer Online work
tboomer  Online Work
Mike...I had the same thing happen to me early this year..I had never used a brake and it was a new learning expierience indeed! Footbraking the car,I would have my left hand at the 10:00 oclock position with my right hand on the shifter..All was well and good! When I went to the brake,I would put my thumb on the wheel mounted button and my left hand was still at the 10:00 oclock position..The car would always go to the left and I swore that there was something wrong with the suspension! I was kinda pissed after sticking that much money in the car to have it act like that!! I posted the same question here that you did and had a lot of help! I changed my driving technique to resting my arm on the door bar with my left hand at the 8:00 oclock position...Problem solved!! The car launches straight and true!! I was my own worst enemy! It took some time to do this repeatedly but now it is old hat...Try it!! It may work for you,too!!
Re: Driving technique help! [Re: 70satelliteguy] #1129635
12/09/11 11:10 AM
12/09/11 11:10 AM
Az
Crizila Offline
Crizila  Offline
Az
If it's not too uncomfortable, try sitting a little closer to the steering wheel. Lots of body movement on launch( soft seat / seat mounting, improper belt installation, etc ) can cause this problem, weather you are jerking the wheels off the ground or not. Many times it's misdiagnosed as a chassis problem - or visaversa.
Fastest 300
Re: Driving technique help! [Re: 70satelliteguy] #1129636
12/09/11 11:20 AM
12/09/11 11:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The best way to find out things is to mount a camera
in the car pointed where you see the wheel... then
watch it in slow mo... normally if you see what you are
doing you can correct it
EDIT
It could be the car lacking/too much preload... if
you were foot braking then changed to a trans brake
you most likely upped the rpm so you would be in a
higher torque range at launch
