69 Super Bee side scoop qwestion?? #1128554
12/06/11 01:31 AM
12/06/11 01:31 AM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
I know...its 'question'. Just being stupid.
Anyhow, is there anything that goes between the fiberglass side scoop and 1/4 panel? Like a thin felt gasket, or maybe some washers at the base of the studs. It just seems weird to be bolted together without something there. I guess it doesnt matter if you indent the paint if the scoops will always be there!
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: 69 Super Bee side scoop qwestion?? [Re: BFASTER] #1128555
12/06/11 11:21 AM
12/06/11 11:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 69 Super Bee side scoop qwestion?? [Re: BFASTER] #1128556
12/06/11 06:35 PM
12/06/11 06:35 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Last time I had mine off was in 92, but based on the attached file and my memory there is no gasket under the stud. The nut has a seal built into it. As I recall the seal was putty on the face of the nut. I would use silicon under the nut or us the washers with the rubber seal on them to seal any water from getting inside. You ca get the washers at Lowes.
6954102-sidescoop026.pdf (127 downloads)
Re: 69 Super Bee side scoop qwestion?? [Re: BFASTER] #1128557
12/06/11 11:50 PM
12/06/11 11:50 PM
Harrisburg Pa. 17112
moparmikethree Offline
the anwer to your qwestion is go to the Home Boy Depot in Harrisburg Pa.
Re: 69 Super Bee side scoop qwestion?? [Re: Dabee] #1128558
12/07/11 11:09 AM
12/07/11 11:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This makes sense , I guess I could have pulled out my FSM to check .
I'd use a sealed in the nut instead of adding a washer wit ha rubber seal that is destined to fail , they don't make rubber like they used to.
