Re: Unstable at speeds [Re: moparmikethree] #1128063
12/07/11 02:55 PM
12/07/11 02:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
I had issues with one set of wheels and tires, I have three different sets , when I mixed bias plys and radials, turn out the wheel lugs( can't think of the proper name for the retainers, lug nuts, on thick center aluminum wheels )where bottoming out on the brake backing plates not keeping the wheels tight against the axles Little stuff can bite the crap out of you My car would go staright as a arrow(128+MPH in the 1/4) with the right set of wheels, not so when I used the wrong rear wheels on it, shortening the wheels retainer shanks up fix it
Re: Unstable at speeds [Re: Cab_Burge] #1128064
12/07/11 06:30 PM
12/07/11 06:30 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Sorry to hijack but I'm having the same problems with my 68 GTX. My front end guy said that to keep the camber right left less than a degree of positive caster on each side. Sure doesn't sound like enough.
Re: Unstable at speeds [Re: moparmikethree] #1128065
12/15/11 11:22 AM
12/15/11 11:22 AM
Harrisburg Pa. 17112
moparmikethree Offline OP
I put the car one the alignment machine. Its no wonder I have issues
Left Right
Camber -0.9 0.1
Caster 0.9 0.2
Toe 0.28 0.19
What are the idea settings for higher speed stability
Re: Unstable at speeds [Re: moparmikethree] #1128066
12/15/11 04:22 PM
12/15/11 04:22 PM
Left Right
Camber -0.9 0.1
Caster 0.9 0.2
Toe 0.28 0.19
I like to see around .15 to .25 camber,(not sure if it is negative or postive camber ) or use the stock specs. for that car As much positive caster as I can get and around 1/16 toe in with the front end raisded up one inch with the drivers weight in the drivers seat and a full tank of gas
Re: Unstable at speeds [Re: Cab_Burge] #1128067
12/15/11 08:06 PM
12/15/11 08:06 PM
IN
ahy Offline
ahy  Offline
IN
Agree as much positive caster as possible and some toe in, about 1/8"-3/16" which should be around stock specs on the high side for stability. For cornering you want a little negative camber. More helps the tires bite in turns. At least -.25 degrees. -.75 camber would help the tires bite even more but you get into a tradeoff with caster.
With stock suspension it can be hard to get enough positive caster. 5 or even 7 degrees of caster would be great. One approach while on the alignment rack is to set both sides for max caster. Even it up between the sides and then set the minimally acceptable negative camber.
Offset UCA bushings or tubular control arms with additional caster built in will help increase both caster and negative camber. See Firm Feel's web site.
Re: Unstable at speeds [Re: ahy] #1128068
12/15/11 10:27 PM
12/15/11 10:27 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Can a torsion bar expert help educate me? Can/does too low of a ride height contribute to poor stability? I had a front end alignment done at a shop on my GTS (all new front end components/bushings/joints), and I'm certain the ride height is too low and the car likes to wander.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Unstable at speeds [Re: GO_Fish] #1128069
12/15/11 10:49 PM
12/15/11 10:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The bars themself wont do it BUT if it has enough
travel it most likely is going toe out during the
travel... being you have softer/smaller bars you
might be hitting the lower control arm snuber and
that could be up-setting it... does your problem
seem to happen on jounce(going down) or rebound(going up)
Re: Unstable at speeds [Re: MR_P_BODY] #1128070
12/16/11 12:03 AM
12/16/11 12:03 AM
IN
ahy Offline
ahy  Offline
IN
Ride height can affect alignment. If this started happening after alignment, maybe you need a better shop.
Re: Unstable at speeds [Re: ahy] #1128071
12/16/11 12:09 AM
12/16/11 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it can but I'm assuming the height was set prior
to the alignment
