Re: 1958 plymouth 12volt generator?
[Re: RV2]
#1127626
12/15/11 07:13 PM
12/15/11 07:13 PM
Posts: 84 Ontario, CANADA
hemi pwr
Ontario, CANADA
I have a flat head six in mine and want to put ina 440 what mounts or do I have to make some
1970 440-6 Cuda
71 duster
1999 Dodge ram diesel dually
1958 plymouth hardtop
1975 Fury 2 door
1970 AAR cuda clone
[Re: hemi pwr]
#1127628
12/15/11 09:09 PM
12/15/11 09:09 PM
Posts: 1,513 AZ
Mike P
AZ
To do it with factory parts, you will need the V8 frame mounts, cylinder style motor mounts, and BB engne mounts (cans) which are differ ent than the SB ones. You will also need an early oil pan. I'm assuming you will be updating the transmission also which will require modifying the crossmember.
The frame monts look like this
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#1127629
12/15/11 09:11 PM
12/15/11 09:11 PM
Posts: 1,513 AZ
Mike P
AZ
The mounts look like this
[Re: Mike P]
#1127630
12/15/11 09:13 PM
12/15/11 09:13 PM
Posts: 1,513 AZ
Mike P
AZ
The frame mount is something like this (this one is for a SB Poly motor).
If you're interested PM me I would sell the frame mounts and motor mounts....sorry I don't have the engine cans for a BB.
