1958 plymouth 12volt generator? #1127621
12/04/11 09:25 PM
12/04/11 09:25 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Does a 58 Plymouth have a 6volt or 12volt system from the factory?
Re: 1958 plymouth 12volt generator? [Re: RV2] #1127622
12/04/11 09:32 PM
12/04/11 09:32 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
Hi, All 1958 Plymouths have 12 volt systems, so yes it does.
Re: 1958 plymouth 12volt generator? [Re: 57Fury440] #1127623
12/04/11 09:38 PM
12/04/11 09:38 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I just purchased a 58 plymouth that has a transplanted 440 and I was thinking of installing the 1970 up charging system, but was worried that this might affect the gauges, will I be ok?
Re: 1958 plymouth 12volt generator? [Re: RV2] #1127624
12/05/11 12:19 AM
12/05/11 12:19 AM
57Fury440 Offline
57Fury440  Offline
Yes, You shouldn't have any problems. My 57 Fury has a 440 in it since the early seventies with an alternator, etc. I also had a few daily driver 57 and 58 Plymouths that I converted to electronic ignition and alternator systems.
Re: 1958 plymouth 12volt generator? [Re: 57Fury440] #1127625
12/05/11 01:18 AM
12/05/11 01:18 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Thanks, I remember seeing your car when I lived in NY
Re: 1958 plymouth 12volt generator? [Re: RV2] #1127626
12/15/11 07:13 PM
12/15/11 07:13 PM
Ontario, CANADA
hemi pwr Offline
hemi pwr  Offline
Ontario, CANADA
I have a flat head six in mine and want to put ina 440 what mounts or do I have to make some
1970 440-6 Cuda 71 duster 1999 Dodge ram diesel dually 1958 plymouth hardtop 1975 Fury 2 door 1970 AAR cuda clone
Re: 1958 plymouth 12volt generator? [Re: hemi pwr] #1127627
12/15/11 07:47 PM
12/15/11 07:47 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I purchased the car with mounts grafted onto the frame already, they are not 50's era mounts, they are sixties setup.
But these cars were available with bigblocks, so you will have to do your home work, check out forwardlook.net for more info.
Re: 1958 plymouth 12volt generator? [Re: hemi pwr] #1127628
12/15/11 09:09 PM
12/15/11 09:09 PM
AZ
Mike P Offline
Mike P  Offline
AZ
To do it with factory parts, you will need the V8 frame mounts, cylinder style motor mounts, and BB engne mounts (cans) which are differ ent than the SB ones. You will also need an early oil pan. I'm assuming you will be updating the transmission also which will require modifying the crossmember.
The frame monts look like this
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 1958 plymouth 12volt generator? [Re: Mike P] #1127629
12/15/11 09:11 PM
12/15/11 09:11 PM
AZ
Mike P Offline
Mike P  Offline
AZ
The mounts look like this
Re: 1958 plymouth 12volt generator? [Re: Mike P] #1127630
12/15/11 09:13 PM
12/15/11 09:13 PM
AZ
Mike P Offline
Mike P  Offline
AZ
The frame mount is something like this (this one is for a SB Poly motor).
If you're interested PM me I would sell the frame mounts and motor mounts....sorry I don't have the engine cans for a BB.
Re: 1958 plymouth 12volt generator? [Re: Mike P] #1127631
12/17/11 06:53 PM
12/17/11 06:53 PM
Ontario, CANADA
hemi pwr Offline
hemi pwr  Offline
Ontario, CANADA
Thanks guys for the info ..and mike thanks I will need all the parts before I do it ...a bit of work but I will do it still
