'67 RC426 Race Hemi bellhousing/starter problem #1127616
12/04/11 08:44 PM
12/04/11 08:44 PM
canada
marfen Offline OP
marfen  Offline OP
canada
Trying to install this great bellhousing in a street hemi application. Have the correct 11" 172 tooth flywheel and direct drive starter. Top of the starter bolts onto the bellhousing with the 7/16 stud. Problem is the bottom of the starter needs to be bolted by a bolt from the back of the bellhousing flange and there is no room for a bolt head hex or allen. Anyone know what was used for fastening the bottom of the starter with this rare part which understandably I don't want to clearance with a grinder. thanks
Re: '67 RC426 Race Hemi bellhousing/starter problem [Re: marfen] #1127617
12/04/11 08:58 PM
12/04/11 08:58 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
looks like that hole isn't centered in the casting. u could tap it & use a stud, or just a smaller bolt. only thing that matters is the starter will be tight. seeya.
Re: '67 RC426 Race Hemi bellhousing/starter problem [Re: marfen] #1127618
12/04/11 11:32 PM
12/04/11 11:32 PM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
I used a socket head (Allen) cap screw on my '67 RO car. In fact, I used socket heads for all of the the bellhousing bolts on my car because of the lack of clearance with hex head bolts. I don't know what they used from the factory, since my car had been converted to an automatic sometime during its life and the original bellhousing and starter were long gone when I got it.
Re: '67 RC426 Race Hemi bellhousing/starter problem [Re: ro23_j] #1127619
12/05/11 10:45 AM
12/05/11 10:45 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Put a thread insert or helicoil in the bell housing and bolt it from the starter side.It will look like a stock factory setup.
Re: '67 RC426 Race Hemi bellhousing/starter problem [Re: B G Racing] #1127620
12/05/11 11:31 AM
12/05/11 11:31 AM
canada
marfen Offline OP
marfen  Offline OP
canada
many thanks folks!
