Is this a 1972-73 340 flywheel #1127441
12/04/11 02:33 PM
12/04/11 02:33 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I have a 130 tooth--6 bolt--12 1/4" total width flywheel
It has a crescent shape cutout on the edge on the back flywheel
No casting or part #'s
Would this be a flywheel for a cast crank 340
Re: Is this a 1972-73 340 flywheel [Re: Dart6pak] #1127442
12/04/11 05:29 PM
12/04/11 05:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Im betting 360..
I am truckless..
Re: Is this a 1972-73 340 flywheel [Re: 340SHORTY] #1127443
12/04/11 05:58 PM
12/04/11 05:58 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
No,I don't think so, 360 has some big holes drilled close to edge to ballance it.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Is this a 1972-73 340 flywheel [Re: express] #1127444
12/04/11 06:58 PM
12/04/11 06:58 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Maybe a 400 steel crank wheel. The 143 Tooth 400 truck wheels have the same flycut. 360 has 3 big holes drilled in it.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Is this a 1972-73 340 flywheel [Re: Dart6pak] #1127445
12/04/11 07:02 PM
12/04/11 07:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IMHO it looks more like a 383 cast crank scallop clutch flywheel using a 10.95 cover/clutch
Mike
Re: Is this a 1972-73 340 flywheel [Re: DAYCLONA] #1127446
12/04/11 08:22 PM
12/04/11 08:22 PM
moparmarks Offline
moparmarks  Offline
Heres one of the gazillon 143T for 400 s/c trucks that I've had. Just pulled another couple weeks back.
Looks like the same flycut.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Is this a 1972-73 340 flywheel [Re: moparmarks] #1127447
12/04/11 08:32 PM
12/04/11 08:32 PM
moparmarks Offline
moparmarks  Offline
360 wheels have three 15/16" holes I believe is what they are.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Is this a 1972-73 340 flywheel [Re: moparmarks] #1127448
12/04/11 08:50 PM
12/04/11 08:50 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I just recounted it again and it is 130 tooth
It did come with a pressure plate and disc.
The clutch measures 11" and bolts up to this flywheel and the disc fits slightly inside.
What is a scalloped clutch?
So if it is for a cast crank 383 will it work on a cast crank 340 1973
Re: Is this a 1972-73 340 flywheel [Re: Dart6pak] #1127449
12/05/11 01:37 PM
12/05/11 01:37 PM
dogdays Offline
dogdays  Offline
NO. won't work.
R.
YES. if you rebalance it along with the complete rotating assembly.
