Fixing a Rallye Center cap. #1127176
12/04/11 12:59 PM
12/04/11 12:59 PM
IMGTX Offline OP
IMGTX  Offline OP
I had a Rallye Center Cap come loose and would wiggle in the rim. I took it off applied Red Locktite and put it back on. 2 months later it's loose again.
Any good suggestions on fixing them? Not a lot of metal in those pot metal standoffs.
Re: Fixing a Rallye Center cap. [Re: IMGTX] #1127177
12/04/11 01:21 PM
12/04/11 01:21 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
JB Weld or some other epoxy down in the threaded holes, screw em together and let, the epoxy harden.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Fixing a Rallye Center cap. [Re: HemiRick] #1127178
12/04/11 01:30 PM
12/04/11 01:30 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I'll 2nd the epoxy idea. Iwould let the epoxy dry before screwing it together though.
Re: Fixing a Rallye Center cap. [Re: MPerry] #1127179
12/04/11 02:25 PM
12/04/11 02:25 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Use a product called Form A Thread, I think Permatex makes it .Works great.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Fixing a Rallye Center cap. [Re: express] #1127180
12/04/11 08:01 PM
12/04/11 08:01 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Heli Coil is the way I fix them , you need a 1/4 20 kit , with the drill bit , tap , inserts and installer. Fixes them for good.
Frank
Re: Fixing a Rallye Center cap. [Re: IMGTX] #1127181
12/04/11 08:24 PM
12/04/11 08:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
a couple of pieces of stranded copper wire works good too
Re: Fixing a Rallye Center cap. [Re: duster2] #1127182
12/06/11 11:45 PM
12/06/11 11:45 PM
IMGTX Offline OP
IMGTX  Offline OP
Frank
I didn't think there was enough metal for that but you should know.
It has 5 stands and two are stripped out while the other 3 will tighten they will not stay that way (even with locktite) so I will start with the helicoil and work up to the form a thread.
If they were the normal centers I have spares but these are the ones with the centers that pop out and I want to keep the set matched.
Thanks again
