Fixing a Rallye Center cap.
#1127176
12/04/11 12:59 PM
12/04/11 12:59 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
I had a Rallye Center Cap come loose and would wiggle in the rim. I took it off applied Red Locktite and put it back on. 2 months later it's loose again. Any good suggestions on fixing them? Not a lot of metal in those pot metal standoffs. Thanks ![](/ubbthreads/images/graemlins/Santa3.gif)
Re: Fixing a Rallye Center cap.
[Re: IMGTX]
#1127177
12/04/11 01:21 PM
12/04/11 01:21 PM
Posts: 4,848 Memphis
HemiRick
Memphis
JB Weld or some other epoxy down in the threaded holes, screw em together and let, the epoxy harden.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1127178
12/04/11 01:30 PM
12/04/11 01:30 PM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
I'll 2nd the epoxy idea. ![](/ubbthreads/images/graemlins/wink.gif) Iwould let the epoxy dry before screwing it together though.
[Re: duster2]
#1127182
12/06/11 11:45 PM
12/06/11 11:45 PM
IMGTX
Heli Coil is the way I fix them , you need a 1/4 20 kit , with the drill bit , tap , inserts and installer. Fixes them for good.
Frank
I didn't think there was enough metal for that but you should know. ![](/ubbthreads/images/graemlins/thumbs.gif)
It has 5 stands and two are stripped out while the other 3 will tighten they will not stay that way (even with locktite) so I will start with the helicoil and work up to the form a thread.
If they were the normal centers I have spares but these are the ones with the centers that pop out and I want to keep the set matched.
Thanks again ![](/ubbthreads/images/graemlins/Santa3.gif)
