Cuda Progress:Slow on my end, but not my engine Builder #1126966
12/04/11 01:07 AM
12/04/11 01:07 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well, the 408 stroker is back together with W2 heads. Just needs the rockers put back on and the lash adjusted and the oil primed, and she is ready to put in the car. Too bad the car isn't ready for the engine yet. Plus he still has the trans to finish, but said that won't take long. Man have I got work to do to finish painting the engine bay...
Hone:
Notch for clearance:
Install girdle and main studs and line hone:
Assembled:
Engine bay:
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126967
12/04/11 01:13 AM
12/04/11 01:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Get all that stuff out of the engine bay and shoot
some color...... the engine is looking for a home
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126968
12/04/11 01:31 AM
12/04/11 01:31 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Right on! Looking good! What intake manifold did you go with?
-Kenny
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: StrokerAspen] #1126969
12/04/11 01:39 AM
12/04/11 01:39 AM
Dragula Offline OP
Dragula  Offline OP
Lots of sanding left to do before I am ready for final paint...Sure would be easier without all that stuff in the way....
That is a Mopar POS one I modified the heck out of...Stupid thing had a heat riser for the plenum built in that I milled off and then had welded back up...I also ground off anything else I didn't need except the part number. Heck the hole for the carb wasn't even close, and I had to mill the opening about 3/16 on the front edge. It was blocking the first two barrels of the carb...
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126970
12/04/11 04:03 AM
12/04/11 04:03 AM
Alberta Canada
Alberta Canada
Just a wee bit of work eh? Kind of looked like it had a heat riser.
-Kenny
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: StrokerAspen] #1126971
12/04/11 11:21 AM
12/04/11 11:21 AM
Amherst,NY
challengermike Offline
Amherst,NY
Yes sanding the engine compartment down for paint sucks.I just got done doing my 72 dart.I sand blasted mine first and welded up all the holes for the heater and alot of ones on the inner fenders.Then after i painted it i noticed when i sprayed it i missed a few spots,lol.I wasnt looking for a show car anyways.
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: challengermike] #1126972
12/04/11 11:23 AM
12/04/11 11:23 AM
Amherst,NY
Amherst,NY
painted
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: challengermike] #1126973
12/04/11 11:30 AM
12/04/11 11:30 AM
Dragula Offline OP
Dragula  Offline OP
painted
Very nice. That is what I am up to, but I am not going to weld up all the little holes on this one. I will be pulling the grill to fix that and repaint that back to argent silver. It seems like it takes forever to sand it all down.....
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126974
12/10/11 04:21 PM
12/10/11 04:21 PM
Dragula Offline OP
Dragula  Offline OP
Latest engine pic....
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: MR_P_BODY] #1126975
12/10/11 07:21 PM
12/10/11 07:21 PM
Dragula Offline OP
Dragula  Offline OP
Made the radiator opening bigger incase I street this car...
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126976
12/11/11 08:01 AM
12/11/11 08:01 AM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
Is that tunnelram W-2 only?
If so is it a good intake?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: fed] #1126977
12/11/11 10:21 AM
12/11/11 10:21 AM
Dragula Offline OP
Dragula  Offline OP
The one I have fits W2 only. I do believe they made them for brand X engines as well, but for Mopar, they only fit the W2 heads.
As far as it being a good tunnel ram, I have seen it used on some low 10.0 cars with good success, so I am assuming it is. When you look down the runners into the ports, its a perfect match on my set-up....
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126978
12/11/11 10:37 AM
12/11/11 10:37 AM
Amherst,NY
Amherst,NY
Why did you have to open up the core support?If your using a crossflow radiator the tanks usually fill uncut space perfect and the fins start at the opening.
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: challengermike] #1126979
12/11/11 11:02 AM
12/11/11 11:02 AM
Dragula Offline OP
Dragula  Offline OP
To fit my 31x19 Radiator...Love these on the street. I haven't seen one yet get to 190*....Besides, its a lot easier before I paint it and the guy who had it before me already put two large holes in it for ram air to the air cleaner. Its not a restoration, we are going racing! Want to buy the stock rad?
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126980
12/11/11 12:21 PM
12/11/11 12:21 PM
Amherst,NY
Amherst,NY
no i just bought a double pass 28 x 19 for the dart.I have had great luck with the double pass one in my coronet 31x 19,it ran 160 all the time with a junkyard dual fan setup.I only had to trim the pinch weld on the frame rail to get that 1 to fit.
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: challengermike] #1126981
12/18/11 07:32 PM
12/18/11 07:32 PM
Dragula Offline OP
Dragula  Offline OP
Man its been cold out... I need a garage heater.
Almost forgot to put the valley trey in the engine. Got to pull the valve train off again to put that back in and the engine is done and has 60psi oil pressure...My W2 is done, just need to finish the trans and paint the engine bay, and the rear axle work can begin
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126982
01/02/12 11:31 PM
01/02/12 11:31 PM
Dragula Offline OP
Dragula  Offline OP
I seem to be going the wrong way on this...I ended up pulling the grill, the bumper, the hood, the master cylinder, and taking it down to bare paint...Aaaargh! Some of the paint underneath was just nasty, so its all or nothing now. And the intake is back out for a little welding and tapping for the extra coolant lines. Figured I would try what most of the other small block guys have done for a while now.
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126983
01/02/12 11:55 PM
01/02/12 11:55 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Didnt I see your new engine up for sale just recently?
RIP Monte Smith
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: CompWedgeEngines] #1126984
01/03/12 12:14 AM
01/03/12 12:14 AM
Dragula Offline OP
Dragula  Offline OP
Yes, but you don't see my truck for sale...I might have something else to drop in if all goes well.
If not, my engine builder and I talked it over, and with the progress slow on the '72 Cuda, the W2 will go into my '70 Cuda for the racing season. I already have the front S&W plate that showed up Friday, and the convertor is out to repair a crack in the snout. Once its back, the W2 will go into my '70 and get fired up unless it sells. We figure it will go 11.0's in my green Cuda..
Re: Cuda Progress:Slow on my end, but not my engine Builder [Re: Dragula] #1126985
01/03/12 12:24 AM
01/03/12 12:24 AM
Syracuse,NY
Syracuse,NY
Got ya....I didnt know you had 2 Cudas...I see now... ...you use KTR right?
RIP Monte Smith
