Cuda Progress:Slow on my end, but not my engine Builder
#1126966
12/04/11 01:07 AM
12/04/11 01:07 AM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Well, the 408 stroker is back together with W2 heads. Just needs the rockers put back on and the lash adjusted and the oil primed, and she is ready to put in the car. Too bad the car isn't ready for the engine yet. Plus he still has the trans to finish, but said that won't take long. Man have I got work to do to finish painting the engine bay... Hone: Notch for clearance: Install girdle and main studs and line hone: Assembled: Engine bay:
Re: Cuda Progress:Slow on my end, but not my engine Builder
[Re: StrokerAspen]
#1126969
12/04/11 01:39 AM
12/04/11 01:39 AM
Dragula
Lots of sanding left to do before I am ready for final paint...Sure would be easier without all that stuff in the way.... That is a Mopar POS one I modified the heck out of...Stupid thing had a heat riser for the plenum built in that I milled off and then had welded back up...I also ground off anything else I didn't need except the part number. Heck the hole for the carb wasn't even close, and I had to mill the opening about 3/16 on the front edge. It was blocking the first two barrels of the carb...
[Re: challengermike]
#1126973
12/04/11 11:30 AM
12/04/11 11:30 AM
Dragula
painted
Very nice. That is what I am up to, but I am not going to weld up all the little holes on this one. I will be pulling the grill to fix that and repaint that back to argent silver. It seems like it takes forever to sand it all down.....
[Re: Dragula]
#1126976
12/11/11 08:01 AM
12/11/11 08:01 AM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Is that tunnelram W-2 only? If so is it a good intake?
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: fed]
#1126977
12/11/11 10:21 AM
12/11/11 10:21 AM
Dragula
The one I have fits W2 only. I do believe they made them for brand X engines as well, but for Mopar, they only fit the W2 heads.
As far as it being a good tunnel ram, I have seen it used on some low 10.0 cars with good success, so I am assuming it is. When you look down the runners into the ports, its a perfect match on my set-up....
#1126979
12/11/11 11:02 AM
12/11/11 11:02 AM
Dragula
Why did you have to open up the core support?If your using a crossflow radiator the tanks usually fill uncut space perfect and the fins start at the opening.
To fit my 31x19 Radiator...Love these on the street. I haven't seen one yet get to 190*....Besides, its a lot easier before I paint it and the guy who had it before me already put two large holes in it for ram air to the air cleaner. Its not a restoration, we are going racing! Want to buy the stock rad?
#1126981
12/18/11 07:32 PM
12/18/11 07:32 PM
Dragula
Man its been cold out... I need a garage heater.
Almost forgot to put the valley trey in the engine. Got to pull the valve train off again to put that back in and the engine is done and has 60psi oil pressure...My W2 is done, just need to finish the trans and paint the engine bay, and the rear axle work can begin
[Re: Dragula]
#1126982
01/02/12 11:31 PM
01/02/12 11:31 PM
Dragula
I seem to be going the wrong way on this...I ended up pulling the grill, the bumper, the hood, the master cylinder, and taking it down to bare paint...Aaaargh! Some of the paint underneath was just nasty, so its all or nothing now. And the intake is back out for a little welding and tapping for the extra coolant lines. Figured I would try what most of the other small block guys have done for a while now.
[Re: Dragula]
#1126983
01/02/12 11:55 PM
01/02/12 11:55 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Didnt I see your new engine up for sale just recently?
RIP Monte Smith
[Re: CompWedgeEngines]
#1126984
01/03/12 12:14 AM
01/03/12 12:14 AM
Dragula
Yes, but you don't see my truck for sale...I might have something else to drop in if all goes well.
If not, my engine builder and I talked it over, and with the progress slow on the '72 Cuda, the W2 will go into my '70 Cuda for the racing season. I already have the front S&W plate that showed up Friday, and the convertor is out to repair a crack in the snout. Once its back, the W2 will go into my '70 and get fired up unless it sells. We figure it will go 11.0's in my green Cuda..
[Re: Dragula]
#1126985
01/03/12 12:24 AM
01/03/12 12:24 AM
CompWedgeEngines
Syracuse,NY
Got ya....I didnt know you had 2 Cudas...I see now... ...you use KTR right?
RIP Monte Smith
