better gears for more purpose use but power to. #1126909
12/03/11 11:28 PM
12/03/11 11:28 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Ok i have a 1966 plymouth Satellite with a 600 hp motor i changed over to a A-833 trans with a 8 3/4 rear with a 489 chunk & 391 gears yes its a posi when i am crusing in forth and hit third hard it hits the rev limiter fast i want more rpm would 3:55 be better or 3:23 any ideas.!
Old car are me......
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126910
12/03/11 11:49 PM
12/03/11 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Think of the gear changes as a percentage so if you
drop X percentage you drop the engine rpm X percentage
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126911
12/03/11 11:53 PM
12/03/11 11:53 PM
Two things, what do you set the rev limiter at? 2nd, is it spinning the tires when you hit it in third gear? Mine does,(727 with a loose converter) if I'm not careful on the loud peddle application 4.10 gears, 13.5x30x15 M/T ET Streets I have my rev limiter set at 8000 RPM, I shift it at or close to 7300 RPM, it runs a 134 MPH in the 1/4 mile crossing the finish line at or close to 7000 RPM
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126912
12/03/11 11:54 PM
12/03/11 11:54 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
MY vote would be a 3.23..
Re: better gears for more purpose use but power to. [Re: Cab_Burge] #1126913
12/04/11 12:37 PM
12/04/11 12:37 PM
Maryville tn
Maryville tn
Yes it did spin very good even into forth gear! & my rev limiter is at 6000 rpm.
Re: better gears for more purpose use but power to. [Re: dOrk !] #1126914
12/04/11 12:38 PM
12/04/11 12:38 PM
Maryville tn
Maryville tn
I was seriously thinking of 3:55 or 3:23 gears.
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126915
12/04/11 12:54 PM
12/04/11 12:54 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You say that you want more rpm, I presume that you mean more usable rpm between your cruise speed and the rev limiter.
Gear choice when balancing crusing against best performance/fun factor, is usally a compromise and boils down to an individuals preference. Do the math as Mr.P suggests, or use an on line calculator to see how the rpm will change with different axle ratios. Also, if the concern is simply bumping into the rev limiter, maybe move it up a few hundred rpm. I would think that you would be shifting around 6000 anyways, and a 600 hp motor should have the internals to safely rev past that.
Re: better gears for more purpose use but power to. [Re: BSB67] #1126916
12/04/11 01:52 PM
12/04/11 01:52 PM
Maryville tn
Maryville tn
Yes a more usable RPM. with my gear as of now 3:91 & my 4-speed it hits the Rev Limiter very fast and it breaks the tires loose so i am spinning & shifting and it keeps spinning & hitting the Rev Limiter i am getting ready to put a taller rear tire from a 27/10.5/15 ET streets to a 275/60/15 drag radials out back which i read is 1" taller i think.
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126917
12/04/11 02:02 PM
12/04/11 02:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Your bigger problem is a lack of TRACTION, you could switch to a 2.76 gear change the rev limiter to 8k rpm and if it's spinning you are still going to be on the rev limiter pretty quickly.
Re: better gears for more purpose use but power to. [Re: JohnRR] #1126918
12/04/11 08:22 PM
12/04/11 08:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That's what I was thinking too. It's not the gear's fault that you're spinning and hitting the rev limiter. Either up the traction or ease up on the pedal. With a 600hp engine, 2.76 rear gears and crappy street tires you'll still be blowing them away and bouncing off the rev limiter.
Re: better gears for more purpose use but power to. [Re: DaytonaTurbo] #1126919
12/04/11 10:36 PM
12/04/11 10:36 PM
Maryville tn
Maryville tn
Yes it is busting the tires loose so i am going to do something cause i am just wasting my time as it is,
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126920
12/04/11 10:49 PM
12/04/11 10:49 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Here's a link to an RPM calculator Randy's ring and pinion RPM calc
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126921
12/05/11 06:52 AM
12/05/11 06:52 AM
Manitoba, Canada
Manitoba, Canada
On the track or on the street? Any car with that kind of power is going to blow away tires on the street no matter what.
Re: better gears for more purpose use but power to. [Re: DaytonaTurbo] #1126922
12/05/11 12:01 PM
12/05/11 12:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you need a wide/sticky tire to gain traction.
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126923
12/05/11 03:27 PM
12/05/11 03:27 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
"Ok i have a 1966 plymouth Satellite with a 600 hp motor i changed over to a A-833 trans with a 8 3/4 rear with a 489 chunk & 391 gears yes its a posi when i am crusing in forth and hit third hard it hits the rev limiter fast i want more rpm would 3:55 be better or 3:23 any ideas.!"
Try the 3.55 gears. They are a good compromise for some freeway use and should get you up into the 140+ to 160+ mph range, depending on how tall your tires are.
Are you having traction problems too?
Tell us about your 600hp engine combination.
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126924
12/05/11 09:58 PM
12/05/11 09:58 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
B body ,600hp, standard transmission, 8.75 rear, traction... ..BANG Before you get some sticky tires, you might consider trading that 8.75 for a __________________.
Re: better gears for more purpose use but power to. [Re: forphorty] #1126925
12/06/11 12:53 AM
12/06/11 12:53 AM
Maryville tn
Maryville tn
Yea i know a Dana 60 way ahead all ready have one but i may get alot of slack on this but that 8 3/4 is more than strong enough.! i have a friend here that had a 900 hp stroker 440 with indy heads and ran a 8 3/4 for years never broke it once.
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126926
12/06/11 11:16 AM
12/06/11 11:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
More info, what body, what did it weigh, pro gears, what did it 60 ft ???
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126927
12/06/11 12:18 PM
12/06/11 12:18 PM
Maryville tn
Maryville tn
Bang.
Re: better gears for more purpose use but power to. [Re: 67coronetman] #1126928
12/06/11 12:57 PM
12/06/11 12:57 PM
dogdays Offline
dogdays  Offline
You could put a 1000 lb-ft torque engine in front of an 8 3/4 and as long as the tires broke free first the rear end would live. It's the amount of torque RESISTANCE that breaks the rear or the driveshaft or the transmission or the u-joints. Also spelled traction or hook.
R.
