throttle cable for e body with hemi t ram? #1126807
12/03/11 06:56 PM
12/03/11 06:56 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i put the t ram on and messed with the linkage man the carbs are stiff
any way it still has the orignal throttle cable (74 challenger 360 4 barrel) and im thinking it is a little long and binding up
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: throttle cable for e body with hemi t ram? [Re: toplescuda] #1126808
12/03/11 07:29 PM
12/03/11 07:29 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
here is some pics
1971 charger
Re: throttle cable for e body with hemi t ram? [Re: toplescuda] #1126809
12/03/11 07:44 PM
12/03/11 07:44 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
1971 charger
Re: throttle cable for e body with hemi t ram? [Re: toplescuda] #1126810
12/03/11 07:53 PM
12/03/11 07:53 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
the bolt surface on the intake is shorter so i had to put a spacer under the throttle bracket to get it off the valve cover
i made the plate that holds the regulator and made my own line setup linkage dont touch anywhere i also made the linkage arm on the intake
not sure whe the pics are sideways i sure didnt take them that way
1971 charger
Re: throttle cable for e body with hemi t ram? [Re: toplescuda] #1126811
12/03/11 09:38 PM
12/03/11 09:38 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You might like to try lighter springs
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: throttle cable for e body with hemi t ram? [Re: hemi-itis] #1126812
12/04/11 12:24 AM
12/04/11 12:24 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
i dont even have a return spring on it yet,assumeing that is what your talking about....never heard of lighter spring on the throttle shafts
1971 charger
Re: throttle cable for e body with hemi t ram? [Re: toplescuda] #1126813
12/04/11 12:35 AM
12/04/11 12:35 AM
hemi-itis Offline
hemi-itis  Offline
Yout right about that
Re: throttle cable for e body with hemi t ram? [Re: toplescuda] #1126814
12/04/11 12:42 AM
12/04/11 12:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Start looking at the ratios of the carb linkage...
if you move the linkage out farther on the carbs it
easier to pull them open BUT you need more travel...
basically look to see how much pedal travel you have
to start with then work it backwards to the carbs,
still trying to keep the best ratio with the travel
you have... also keep the cable as straight as possible
