Re: Rusty
[Re: JDMopar]
#1126658
12/03/11 01:10 PM
12/03/11 01:10 PM
Posts: 905 SD
zrxkawboy
SD
Maybe you could try one of the rust treatment/converter products, such as the ones from Eastwood, etc.
As for the gasket, yes, NAPA should have it. Otherwise, I've had good results with "Right Stuff" gasket maker on diffs.
It's Swifty! Swifty, you toad sucker!
Re: Rusty
[Re: Tadams]
#1126660
12/03/11 03:38 PM
12/03/11 03:38 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
They have the rust converter in a spray can here at the parts store. Works great. Ya still gottas knock off the surface rust then spray it. Goes on clear then turns kinda flat black. I've used it on all kinda stuff even small spots on 1/4 panels. Makes the metal hard again and is sandable and paintable.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
