w2 style hedman hustler? #1126606
12/03/11 11:06 AM
12/03/11 11:06 AM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
Hey guys anyone w a sb ever use the pt# 75130 2" to 3 1/2" hedmans(W2 STYLE),i wanna know if there the fender well headers? im not lookin to chop the inner wells..thanks AndyB
Re: w2 style hedman hustler? [Re: fishy340] #1126607
12/03/11 11:13 AM
12/03/11 11:13 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Re: w2 style hedman hustler? [Re: Hot 340] #1126608
12/03/11 06:21 PM
12/03/11 06:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
no they are not fenderwell headers, but you will have to open a passage in the fenderwell for one tube.
Re: w2 style hedman hustler? [Re: dartman366] #1126609
12/03/11 06:29 PM
12/03/11 06:29 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
The link says...One pipe one side over frame.
Re: w2 style hedman hustler? [Re: Hot 340] #1126610
12/03/11 06:54 PM
12/03/11 06:54 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Actually it's 1 pipe on each side ( 7&8 tubes) go through the fenderwell and over the frame.
I have that exact set on my Valiant. Oh, and forget running a "kickout sump" pan with them. Either have to run a moroso style straight sided pan, or have a your pan cut and modified.
Re: w2 style hedman hustler? [Re: 340_Dart] #1126611
12/03/11 07:29 PM
12/03/11 07:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have the standard port Hedmans on my Dart . It also has a Milodon pan that I modified to clear the headers.
Re: w2 style hedman hustler? [Re: justinp61] #1126612
12/03/11 07:31 PM
12/03/11 07:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Passengers side.
Re: w2 style hedman hustler? [Re: justinp61] #1126613
12/03/11 07:58 PM
12/03/11 07:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Does the exit pipe limit steering and can you still use a 28" tire on front?
Re: w2 style hedman hustler? [Re: Hot 340] #1126614
12/03/11 08:43 PM
12/03/11 08:43 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
thankyou guys for the pics and the feedback,im gonna be hittin it pretty hard with spray&good exhause always help! but i'll see how the tti's hold up & try and save some coin,cause 2013 will be a w9 yr(i'f i still have a job then lol)
Re: w2 style hedman hustler? [Re: Hot 340] #1126615
12/03/11 10:27 PM
12/03/11 10:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I can't run anything bigger than 26", it hits the fender, not the header.
Re: w2 style hedman hustler? [Re: justinp61] #1126616
12/04/11 01:14 AM
12/04/11 01:14 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I have a set of A body Hedman Huslers for my 67 valiant. How well do they fit? I have the same headers, but the FJM body style in my Aspen, and the fit was TERRIBLE. I ended up lifting the drivers side of the engine about a 1/2" to avoid bashing the tubes badly. The FJM headers have been discontinued, maybe because of the terrible fit. I hope my a-body ones fit better.
-Kenny
Re: w2 style hedman hustler? [Re: StrokerAspen] #1126617
12/04/11 04:35 AM
12/04/11 04:35 AM
San Diego
formula S Offline
formula S  Offline
San Diego
We used those on a duster and they fit fine but the tubes are to close to the pan to run a diaper we tried and even wraped the tubes to keep from burning the diaper but it still cooked it
Re: w2 style hedman hustler? [Re: formula S] #1126618
12/04/11 05:11 PM
12/04/11 05:11 PM
SoCal
Brian Hafliger Offline
SoCal
How did Ted's new headers fit?
Brian Hafliger
Re: w2 style hedman hustler? [Re: Brian Hafliger] #1126619
12/05/11 01:19 PM
12/05/11 01:19 PM
San Diego
formula S Offline
formula S  Offline
San Diego
He still hasnt fixed the car but I suggested he have custom headers built because he has coilovers instead of torsion bars so now there is room to put the header tubes out of the way of the pan and diaper
