Re: w2 style hedman hustler?
[Re: Hot 340]
#1126608
12/03/11 06:21 PM
12/03/11 06:21 PM
dartman366
Mt. Vernon, Ohio
no they are not fenderwell headers, but you will have to open a passage in the fenderwell for one tube.
[Re: dartman366]
#1126609
12/03/11 06:29 PM
12/03/11 06:29 PM
Posts: 3,395 Pa
Hot 340
Pa
The link says...One pipe one side over frame.
[Re: Hot 340]
#1126610
12/03/11 06:54 PM
12/03/11 06:54 PM
Posts: 1,745 Maryland
340_Dart
Maryland
Actually it's 1 pipe on each side ( 7&8 tubes) go through the fenderwell and over the frame.
I have that exact set on my Valiant. Oh, and forget running a "kickout sump" pan with them. Either have to run a moroso style straight sided pan, or have a your pan cut and modified.
[Re: Hot 340]
#1126615
12/03/11 10:27 PM
12/03/11 10:27 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Does the exit pipe limit steering and can you still use a 28" tire on front?
I can't run anything bigger than 26", it hits the fender, not the header.
[Re: Brian Hafliger]
#1126619
12/05/11 01:19 PM
12/05/11 01:19 PM
Posts: 660 San Diego
formula S
San Diego
We used those on a duster and they fit fine but the tubes are to close to the pan to run a diaper we tried and even wraped the tubes to keep from burning the diaper but it still cooked it
How did Ted's new headers fit?
He still hasnt fixed the car but I suggested he have custom headers built because he has coilovers instead of torsion bars so now there is room to put the header tubes out of the way of the pan and diaper
