Re: Running car with no exhaust??
[Re: MoparforLife]
#1126575
12/03/11 10:40 AM
12/03/11 10:40 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
how many race cars out there with open headers?
how many "mud trucks" with nothing more than about a 2 foot length of pipe, bent to go straight up out of the hood?
you'll be fine, as long as there's nothing that the hot exhaust gasses can melt or burn in their path.
**Photobucket sucks**
[Re: babarracuda]
#1126582
12/03/11 10:50 PM
12/03/11 10:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I worked in the exhaust lab at Chrysler for 35 years and we would need to measure the stress on the exhaust, the gauges couldnt take the temps so I would weld a plug over the manifold exit then drill a hole in the top of the manifold and weld a length of tubing so it would exit over the roof line... we beat on those cars ALL DAY LONG for days and never burnt a valve
[Re: Russ_Davis]
#1126583
12/03/11 11:54 PM
12/03/11 11:54 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
i ran open headers on my demon. got pretty good at stabbing the clutch, and killing the ignition as i rolled past cops, then cranking it back up, after they had gone by. on the highway, the droning sound gets to be a bit monotonous. i wore ear plugs for any driving more than a quick trip somewhere local. night driving was fun, as running WOT would make the coolest orange glow under the car. killing the ignition while in gear, then cutting it back on, made for awesome backfires, again that looked pretty cool in the dark.
[Re: Golden-Arm]
#1126584
12/04/11 12:15 AM
12/04/11 12:15 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Running open headers is way-diff than using mans only ---with no head pipe. With no head-pipe .. the motor can inject some cold air(through the exit in the exh-man) and TWEAK the exh valves.
[Re: dOrk !]
#1126585
12/04/11 12:26 AM
12/04/11 12:26 AM
MR_P_BODY
Blown engines dont need any pipes... what happens to them.... they only run pipes to get the exhaust past the body..... plus they also give down force
[Re: dogdays]
#1126589
12/05/11 04:01 PM
12/05/11 04:01 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
OK but make sure they are sealed to the head. This is where my problems comes from. Broken bolts = burnt valves. Those valves were burnt and not just a cherished belief.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1126590
12/05/11 04:17 PM
12/05/11 04:17 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The cherished belief was more that the cooler ambient air hitting the hot valve on shut down would cause the valve to warp, not cause them to burn. At least that is the way I was always told Never seen it though or any valve damage that would lead to believe that it was caused by no exhaust.
