Running car with no exhaust?? #1126572
12/03/11 07:12 AM
12/03/11 07:12 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Does it do any harm to run and engine with only the manifolds. I know wear ear plugs.
Re: Running car with no exhaust?? [Re: Russ_Davis] #1126573
12/03/11 10:16 AM
12/03/11 10:16 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I've done it
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Running car with no exhaust?? [Re: 69L78Nova] #1126574
12/03/11 10:29 AM
12/03/11 10:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Won't hurt anything. Another myth saying that it will.
Re: Running car with no exhaust?? [Re: MoparforLife] #1126575
12/03/11 10:40 AM
12/03/11 10:40 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
how many race cars out there with open headers?
how many "mud trucks" with nothing more than about a 2 foot length of pipe, bent to go straight up out of the hood?
you'll be fine, as long as there's nothing that the hot exhaust gasses can melt or burn in their path.
**Photobucket sucks**
Re: Running car with no exhaust?? [Re: Russ_Davis] #1126576
12/03/11 10:56 AM
12/03/11 10:56 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Manifolds are a little short. Too much ox. getting too close to the exhaust valves. I've seen some do it, but there's a big diff. between the extra collector length on headers and such and stock mani's. I wouldn't let it run very long, certainly not on a break in run up. I've started motors just to see if they do, but only fo 30 sec. or so, but's that's me.
Re: Running car with no exhaust?? [Re: 70Cuda383] #1126577
12/03/11 11:14 AM
12/03/11 11:14 AM
X2
Re: Running car with no exhaust?? [Re: RapidRobert] #1126578
12/03/11 11:17 AM
12/03/11 11:17 AM
BDW Online content
BDW  Online Content
Drove several cars this way to the exhaust shop when getting work done. Don't think I could handle it long term.
Re: Running car with no exhaust?? [Re: BDW] #1126579
12/03/11 06:30 PM
12/03/11 06:30 PM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
I am doing a 426ramcharger and plan to have the stock exhaust caps open most of the time. My wife says I can't hear anyway.
Re: Running car with no exhaust?? [Re: DANA60] #1126580
12/03/11 07:30 PM
12/03/11 07:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is what I have always been told.
From personal experiance, I have had a couple big blocks burn the exhaust valve from just a broken manifold bolt. Always seems to be the number 2 cylinder. (?) I suppose it will matter how long you plan to run it that way.
I have mechanical Aptitude.
I can screw up anything.
Re: Running car with no exhaust?? [Re: bboogieart] #1126581
12/03/11 09:04 PM
12/03/11 09:04 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
If you run it at operating temp with exhaust manifolds open, plan on a burnt valve or 2 unless it is rich as a pig (not likely since open exhaust will lean it out). Ask me how I know.
Re: Running car with no exhaust?? [Re: babarracuda] #1126582
12/03/11 10:50 PM
12/03/11 10:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I worked in the exhaust lab at Chrysler for 35 years
and we would need to measure the stress on the exhaust,
the gauges couldnt take the temps so I would weld
a plug over the manifold exit then drill a hole in
the top of the manifold and weld a length of tubing
so it would exit over the roof line... we beat on
those cars ALL DAY LONG for days and never burnt a valve
Re: Running car with no exhaust?? [Re: Russ_Davis] #1126583
12/03/11 11:54 PM
12/03/11 11:54 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i ran open headers on my demon. got pretty good at stabbing the clutch, and killing the ignition as i rolled past cops, then cranking it back up, after they had gone by. on the highway, the droning sound gets to be a bit monotonous. i wore ear plugs for any driving more than a quick trip somewhere local.
night driving was fun, as running WOT would make the coolest orange glow under the car. killing the ignition while in gear, then cutting it back on, made for awesome backfires, again that looked pretty cool in the dark.
Re: Running car with no exhaust?? [Re: Golden-Arm] #1126584
12/04/11 12:15 AM
12/04/11 12:15 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Running open headers is way-diff than using mans only ---with no head pipe. With no head-pipe .. the motor can inject some cold air(through the exit in the exh-man) and TWEAK the exh valves.
Re: Running car with no exhaust?? [Re: dOoC] #1126585
12/04/11 12:26 AM
12/04/11 12:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Blown engines dont need any pipes... what happens to
them.... they only run pipes to get the exhaust past
the body..... plus they also give down force
Re: Running car with no exhaust?? [Re: MR_P_BODY] #1126586
12/04/11 04:47 AM
12/04/11 04:47 AM
Iowa
RSG Offline
RSG  Offline
Iowa
Seems like everyone is saying approximately the same thing I have always heard. None of this is in play when the engine is running of course since cool air can't get back in when the exhaust is rushing out. So what happens when you shut it off? Supposedly manifolds are short enough that cool air can reach the valves before that air would be warmed by the manifold, so the cool air damages the valves. Headers or zoomies are (supposedly) long enough that the cool (ambient) air doesn't reach the valves to damage them. Are the tubes long enough that the air gets heated enough that when it arrives at the valves it isn't a problem, or does the air never really flow up a dead end long passageway at all? I don't have a clue, but I do know a couple people that had problems after running new engine installs (manifolds only) around town a day or two goofing off before taking the time to get exhaust installed. I have also seen my uncle and two buddies do break in runs and test drives on plenty of engines (open manifolds or headers only) and they never had a problem, but they always insisted on stuffing cloth shop rags in the manifold or collector hole as soon as the engine is shut off. Maybe they were being paranoid on the headers but that is what they did. You'd probably have to be an old timer to even remember when shops had red cloth "grease rags" that were picked up and laundered every week. The blue paper towels everyone uses now won't work so well. LOL
You be the judge, this is just what we did and it seemed to work. Even if it is hog dip, I will be following this practice with old towels since it makes me feel like I'm doing the right thing.
Re: Running car with no exhaust?? [Re: RSG] #1126587
12/04/11 08:04 AM
12/04/11 08:04 AM
Pittsfield, Mass.
Pittsfield, Mass.
Thanks for the replys. I only want to run it short periods, like in and out of the garage and around the driveway. 5-10 min.
Re: Running car with no exhaust?? [Re: Russ_Davis] #1126588
12/05/11 01:57 PM
12/05/11 01:57 PM
dogdays Offline
dogdays  Offline
It's amazing what lengths people will go to to defend their cherished beliefs even when they aren't true.
Ever wonder why most of these beliefs make life more complicated?
R.
Re: Running car with no exhaust?? [Re: dogdays] #1126589
12/05/11 04:01 PM
12/05/11 04:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
OK but make sure they are sealed to the head. This is where my problems comes from.
Broken bolts = burnt valves.
Those valves were burnt and not just a cherished belief.
Re: Running car with no exhaust?? [Re: bboogieart] #1126590
12/05/11 04:17 PM
12/05/11 04:17 PM
Upper Midwest
Upper Midwest
The cherished belief was more that the cooler ambient air hitting the hot valve on shut down would cause the valve to warp, not cause them to burn. At least that is the way I was always told Never seen it though or any valve damage that would lead to believe that it was caused by no exhaust.
