Page 4 of 10 1 2 3 4 5 6 9 10
Re: Junkyard D150 Progress [Re: 1E2C] #1125335
12/17/11 09:52 PM
12/17/11 09:52 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks Scratch and Mike for the good info..
Re: Junkyard D150 Progress [Re: hp383] #1125336
12/19/11 12:19 PM
12/19/11 12:19 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Just an FYI, Rock Auto currently has a smoking closeout deal on the 2710 Anchor Brand mounts! $6.41 + ship each! I bought 2 pairs (4 mounts) and it was $34.30 to my door! For that price I'll have 'em on the shelf when I get ready for 'em.
Also installed the motor mount brackets; will have to decide what mounts to use as the 512 shakes a bit at idle (at least it did in the Coronet I had it in previously)
Diesel Same style rubber mount as slant 6 to 440
As Harry mentioned the 89-93 Diesel motor mounts are a bolt in fit for the /6 and v8 engines.
I used them on my 440 swap in the Ramcharger. They are a tad taller, maybe 3/16 to 1/4 inch. But they have more material, and are very tough. Also they have the locking tabs so if they do fail, the motor wont jump out and head down the road by itself.
Surprisingly the mount on the left is the cheaper Anchor #2710 and it has more material, and is better than the more expensive NAPA mount.
The middle is the stock, factory mount, well torn.
For more info, and a followup on the mounts performance after racing, follow the link:
Anchor #2710 1st gen Diesel motor mount
Re: Junkyard D150 Progress [Re: Jwilli500] #1125337
12/19/11 01:40 PM
12/19/11 01:40 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks Jwilli500, I am using the diesel mounts and like you said there is a lot more mateerial than the stock mounts.
1E2C thanks for the parking brake bellcrank; I polished the bolt, lubed it, painted it and it moves like a pendelum on a cukkoo clock.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125338
12/20/11 04:12 AM
12/20/11 04:12 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Good deal Larry, nice to know things work out sometimes.
Re: Junkyard D150 Progress [Re: 1E2C] #1125339
12/20/11 04:02 PM
12/20/11 04:02 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Hooked up the pitman arm, installed PS lines to the box and saginaw pump. No leaks so far; I'll have to figure out what pulley I need for the pump, appears that I need a big block press on pulley so the belts will line up. Pulleys, fuel pump and lines next.. Anyone know if they make a 3/8" pickup/sending unit for this D150? Might have to run a fuel cell in the bed...
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125340
12/20/11 04:04 PM
12/20/11 04:04 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Side view
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125341
12/20/11 07:23 PM
12/20/11 07:23 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Decided to use adel clamps to keep the lines from rubbing each other and it looks neater too.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125342
12/20/11 07:27 PM
12/20/11 07:27 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Side view of the plumbing
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125343
12/21/11 09:27 AM
12/21/11 09:27 AM
scratchnfotraction Offline
IIRC they dodnt have a 3/8 pick up for them,I think you could make it into 3/8 maybe??
I went with the cel in the bed sitting on 500 CI caddy pistons.
you can drop in thru the floor in the back to hide it as well
I hung my filter and pump on the frame rail and run a 1/2 feed with a 3/8 to car with a 3/8 return line.
Re: Junkyard D150 Progress [Re: Jwilli500] #1125344
12/21/11 11:46 AM
12/21/11 11:46 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Thaks for the heads up!
Just ordered 6 of them. Less than 10 each to my door! They only have 8 left at this price!
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125345
12/21/11 02:37 PM
12/21/11 02:37 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Scratch, thats a good idea; I thin I'll pull the sending unit out and see how hard it would be to make it a 3/8" pickup. Are the sending units still avialable? I have looked but not found any sites that offer them.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125346
12/21/11 03:39 PM
12/21/11 03:39 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I just bought a new sending unit for my 78 through my dealer, still a good number.
Kasey
Re: Junkyard D150 Progress [Re: Moparnut426] #1125347
12/21/11 06:47 PM
12/21/11 06:47 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks moparnut426; I have a parts book so I'll see if they are still available.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125348
12/21/11 10:40 PM
12/21/11 10:40 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
thats a very clean truck your building Hemi_Ram, heres a site that has alot of dodge truck parts even fuel sending units
http://www.jimsautoparts.com/nos_truck_parts.htm
Re: Junkyard D150 Progress [Re: 98RAM1500] #1125349
12/22/11 01:16 AM
12/22/11 01:16 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
JIMS?!?!?!?
https://board.moparts.org/ubbthreads/show...rue#Post6869782
is only the latest thread on this place...
Re: Junkyard D150 Progress [Re: RodStRace] #1125350
12/22/11 01:53 AM
12/22/11 01:53 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks for the link to Jim's but oh my goodness the prices are so out of site that they are more than a Hemi RR or and A12 car. Are these D150s going to be on the block for $100,000.00 at Barrett Jackson?? No thanks, when he wants $119.00 for a shifter boot. He will have his inventory of Dodge truck parts for many many years....I have restored many A bodies and B bodies and never spent what he wants for the truck parts....
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125351
12/22/11 08:45 AM
12/22/11 08:45 AM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Yeah I thought they were alittle pricey myself lol, especailly the dome lamp lens for the interior, I have like 5 or 6 of them lying around in a parts barn.
Re: Junkyard D150 Progress [Re: 98RAM1500] #1125352
12/23/11 01:23 AM
12/23/11 01:23 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well, went out today to Swangler Wrecking/Auto Parts and they hooked me up with the pulleys I needed for the crank and waterpump.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125353
12/28/11 03:50 PM
12/28/11 03:50 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Installed the crank and waterpump pullies after cleaning and painting them. Should have the PS pulley on later this week. Finished scraping/sanding/wire brushing the rest of the frame and coated it with rustoleum satin; a few areas I will have to touch up but it's good enough for now. Also removed the rear diff and springs; will have to decide on the springs and what diff to run. Looks like the big HP trucks are running some sort of caltracs by the posts I read.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125354
12/28/11 03:52 PM
12/28/11 03:52 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another pix from the rear.
