TRANS FRESHEN-UP..PARTS & COST? #1124768
12/01/11 12:45 AM
12/01/11 12:45 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks to Randy Johnson(Dartin) his son Sean,and Mr. P-Body..for the use of his engine hoist,I've got my engine and trans out of the GTX...getting it ready for new paint. Since the trans is out..and hasn't been apart since 2001,when it was re-built!..I think it's time to be taken apart,and inspected! New clutch packs would probably be a good idea,as well as replacing all seals and whatever else that NEEDS to be replaced! The sprag is a bolt-in unit,not sure the manufacturer,though!It's held up VERY WELL the past 10 yrs...with NO problems whatsoever! What suggestions do you guys have...and what would be a "ball park" price to do a usual street/strip 727,behind a 550-575hp 440 in a 3500 lb. GTX,with a 9.5"..4500rpm stall speed converter? When I had it done in 2001,it was taken out..rebuilt..and re-installed, for $700.00..which I thought was a VERY FAIR price! Thanks in advance for your opinions...and time! Randy B.
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: Labratt] #1124769
12/01/11 12:48 AM
12/01/11 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Parts are $102 over in Pontiac
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: MR_P_BODY] #1124770
12/01/11 12:54 AM
12/01/11 12:54 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Raff..where at in Pontiac?...what parts?..bands,clutches,steels?
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: Labratt] #1124771
12/01/11 01:02 AM
12/01/11 01:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its the place where 59 dumps into Pontiac... I got
my 518 parts there... Transgo kit... has the seals,
clutches, steels, bands
I forget the name of the company but I can find out
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: MR_P_BODY] #1124772
12/01/11 01:23 AM
12/01/11 01:23 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Mike! If I have everything I need in a kit like that..how much you think labor would be to do the tearing-down..inspecting..and installing the new "stuff"? I haven't called Randy & Shawn's trans guy yet. I was just trying to get an idea how much it SHOULD run me,before I called him.
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: Labratt] #1124773
12/01/11 01:29 AM
12/01/11 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont know ... could be from $150 -$250
I'll talk to you tomorrow about that when you come by
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: MR_P_BODY] #1124774
12/01/11 01:37 AM
12/01/11 01:37 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Will do!
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: Labratt] #1124775
12/01/11 03:03 AM
12/01/11 03:03 AM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Gordons in pontiac
www.gordontransparts.com
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: MCHBOB] #1124776
12/01/11 06:34 AM
12/01/11 06:34 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Is General Trans on Grand River still in biz ? ...
I would just pressure-check-it and if things are cool just change the reaction shaft sealing rings.
Now if you are running HUGE line-pressures ... diff story .. but I don't think you would get 10 years out of one of those.
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: MCHBOB] #1124777
12/01/11 10:08 AM
12/01/11 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Gordons in pontiac
Yep, thats the place....... I had a brain fart
Re: TRANS FRESHEN-UP..PARTS & COST? [Re: MR_P_BODY] #1124778
12/01/11 11:23 AM
12/01/11 11:23 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Did Sean give you Van Geibel's number by chance? He has a 69 Camaro that he races in the All Motor Class at Milan. He does great work& alot of guys use him locally. He'll tear it apart, inspect it, tell you what you need & price it from there.
PM me if you want his number.
