Crank #1124580
11/30/11 08:23 PM
11/30/11 08:23 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
I'm looking to build a B-Block 470, I need a 3.915" crank. The problem is 440source is out, none til Feb. Any 1 else know where I can get a reasonably priced 1? Help.
Re: Crank [Re: PRZ] #1124581
11/30/11 08:40 PM
11/30/11 08:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
wong choice
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Crank [Re: WHITEDART] #1124582
11/30/11 08:43 PM
11/30/11 08:43 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
tell me why please
Re: Crank [Re: PRZ] #1124583
11/30/11 09:11 PM
11/30/11 09:11 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Maybe Ohio crankshaft?
Re: Crank [Re: PRZ] #1124584
11/30/11 09:12 PM
11/30/11 09:12 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
If K1 makes that unit it would be my first choice on the low end of cost.
Re: Crank [Re: PRZ] #1124585
11/30/11 09:14 PM
11/30/11 09:14 PM
gregsdart Offline
gregsdart  Offline
The b block 470 is a great combo, and was originally developed to work well with the stock size BB port and use a cheap, stock offset ground crank. Now with the availability of many different combos, it just makes sense to go bigger. A 4.25 stroke is 512, makes a very good combo with the small rod bearing. The 499 with a 4.15 stroke is great also, using the standard mopar rod bearing. Either will be faster than the 470 due to a fatter torque curve at lower rpms in most cases.
Re: Crank [Re: PRZ] #1124586
11/30/11 09:16 PM
11/30/11 09:16 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I can help you out right here.
Please PM me your contact info, and/or check your PMs.
Thank you
Todd
RIP Monte Smith
Re: Crank [Re: PRZ] #1124587
11/30/11 09:19 PM
11/30/11 09:19 PM
NC
440Jim Offline
440Jim  Offline
NC
Are you looking to build a mild street engine, or a race engine? What heads are you planning to use?
Although it is hard to argue with the 4.250" (511-512 CID), for a street engine with factory iron heads or even out-of-the-box RPM heads, the 3.915" stroke is just fine.
Re: Crank [Re: 440Jim] #1124588
11/30/11 09:24 PM
11/30/11 09:24 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
Ported 440-1s
