Re: Crank
[Re: PRZ]
#1124584
11/30/11 09:12 PM
11/30/11 09:12 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
If K1 makes that unit it would be my first choice on the low end of cost.
Re: Crank
[Re: PRZ]
#1124585
11/30/11 09:14 PM
11/30/11 09:14 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The b block 470 is a great combo, and was originally developed to work well with the stock size BB port and use a cheap, stock offset ground crank. Now with the availability of many different combos, it just makes sense to go bigger. A 4.25 stroke is 512, makes a very good combo with the small rod bearing. The 499 with a 4.15 stroke is great also, using the standard mopar rod bearing. Either will be faster than the 470 due to a fatter torque curve at lower rpms in most cases.
Re: Crank
[Re: PRZ]
#1124586
11/30/11 09:16 PM
11/30/11 09:16 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I can help you out right here.
Please PM me your contact info, and/or check your PMs.
Thank you
Todd
RIP Monte Smith
