How long does it take to replace a CV axle shaft #1124261
11/29/11 09:20 PM
11/29/11 09:20 PM
SC
V194 Offline OP
V194  Offline OP
SC
In a 96 Voyager?
Trying to anticipate the labor cost.
Re: How long does it take to replace a CV axle shaft [Re: V194] #1124262
11/29/11 09:26 PM
11/29/11 09:26 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
IN a shop with air-tools ? ... 1/2 hour.
Re: How long does it take to replace a CV axle shaft [Re: dOrk !] #1124263
11/29/11 09:47 PM
11/29/11 09:47 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Most shops will charge you between 1 to 2 hours to change it tho.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: How long does it take to replace a CV axle shaft [Re: dOrk !] #1124264
11/29/11 09:52 PM
11/29/11 09:52 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I don't know if most of us would get it apart in a half hour. That thing's been together for better than 15 years.
Even with air tools, unless you plan on replacing some other parts you bust by blowing it apart, I'ld bank on a couple of hours. Give or take.
If the knuckle has been off recently, then it would go a lot quicker.
Master, again and still
Re: How long does it take to replace a CV axle shaft [Re: DaveRS23] #1124265
11/29/11 10:18 PM
11/29/11 10:18 PM
SC
V194 Offline OP
V194  Offline OP
SC
Thanks.
Its on its third transmission and second engine.
Re: How long does it take to replace a CV axle shaft [Re: DaveRS23] #1124266
11/29/11 10:45 PM
11/29/11 10:45 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Last year ...on my '90 Caravan ...a 5 speed half-shaft ...... me and a bud ...on his lift with air ....NO MORE than 20 minutes. And it had never been taken apart before.
A couple of hours? ... ...maybe taking a couple of breaks with a few pizzas and a case of beer ..
Re: How long does it take to replace a CV axle shaft [Re: dOrk !] #1124267
11/30/11 06:13 AM
11/30/11 06:13 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Well, I've done my share of these and it just sounds like you're a lot faster than me, Doc. Maybe I could get you to come over and do my next one?
Re: How long does it take to replace a CV axle shaft [Re: V194] #1124268
12/01/11 02:50 AM
12/01/11 02:50 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Jack it up, slap a jacks tand under the frame, yank the wheel and zip the nut off the half shaft. Pull the lower ball joint nut and pop loose. Tap the half shaft through the hub, pry the other half loose from the transaxle (provided it's not a bolt together issue), pull the rotor away from the half shaft and pull the half shaft out of the way. Reassemble in the reverse order.
Course if it's one of those [Email]b@stards[/Email] that you can't remove the lower joint without first removing the cv axle (because it's in the way), you may have to disconnect the knuckle from the top side, however you have to do it. Just don't loosen anything up that adjusts alignment.
Just found a blown up image on google and if it's accurate, you should be able to remove the lower ball joint nut, pop it loose from the knuckle, and get enough clearance that way. Be careful not to damage the dust boot on the ball joint. You may have to pop the tie rod end loose as well and possibly hang the caliper somewhere else so the line doesn't limit how far you can move the hub out of the way.
Just realized you said anticipate the labor costs. I suggest calling around. Find out if it's cheaper to buy your own parts and bring them or have them supply the parts. Sometimes parts stores give shops a break on parts costs so the shop can mark things up a bit and make some money on parts as well as labor. I'm mentioning this because where I work, we get such decent prices on parts that when we mark them up, they often come in cheaper than what Joe off the street would pay just by walking into the same parts store. Some food for thought, don't automatically think the shop is ripping you off on parts.
Re: How long does it take to replace a CV axle shaft [Re: dodgeboy11] #1124269
12/01/11 09:19 AM
12/01/11 09:19 AM
SC
V194 Offline OP
V194  Offline OP
SC
It cost $90 in labor per side plus $70 for the shaft each total was around $390.00
Re: How long does it take to replace a CV axle shaft [Re: V194] #1124270
12/01/11 09:28 AM
12/01/11 09:28 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think book time is 1 hour.
Mopar warrenty times is something like .6 tenths
Sounds like your price is in line.
Re: How long does it take to replace a CV axle shaft [Re: 71yelladustr] #1124271
12/01/11 11:33 AM
12/01/11 11:33 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is how they make money, the book says 2 hours it gets charged for 2 hours. Get it done sooner and you are making money. I know several guys that put out supposedly 12 to 18 hours in an 8 hour day.
I have mechanical Aptitude.
I can screw up anything.
Re: How long does it take to replace a CV axle shaft [Re: bboogieart] #1124272
12/01/11 09:10 PM
12/01/11 09:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I have a frind with a shop,takes him about twenty minutes.
Re: How long does it take to replace a CV axle shaft [Re: 62maxwgn] #1124273
12/01/11 09:42 PM
12/01/11 09:42 PM
Missouri U.S.A.
Missouri U.S.A.
I bet he will charge the customer for more than 20 minutes! Its not about how long it takes, its more about what the job pays. Thats how technicans make money. Though sometimes it does not always work in their favor. Having the right tools and the know how is got to be worth something.
10.02@134
Re: How long does it take to replace a CV axle shaft [Re: 71yelladustr] #1124274
12/01/11 10:46 PM
12/01/11 10:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
How quick they come apart really depends on where you are. I just had to change the front wheel bearing my my SIL's GMC 4x4. Never did it before so I googled it and there we a number of YouTube video's out there, all of them saying "you will spend hours with hammer, chisels,, gas wrench, etc. getting the old bearing out". Took my 15 minutes to swap them. I do not live where rust is an issue, nor salt.
I changed a number of CV shafts out in my 86 Daytona, similar to the Caravan's setup. I could do both in 30 minutes without having to touch the ball joints. Jack up car, pull tires, remove axle nut, smack end of axle stub with a hammer to pop it loose, crank the steering wheel all the way over (opposite direction from the side you are working on), pull shaft out, put in new, reassemble. Air tools though.
Don't be the exception.
Re: How long does it take to replace a CV axle shaft [Re: Supercuda] #1124275
12/02/11 01:18 AM
12/02/11 01:18 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
...do I hear "bidding" TWENTY MINUTES for both ? ..
You SLACKERS saying 1 to 2 hours for ONE ....
Re: How long does it take to replace a CV axle shaft [Re: 71yelladustr] #1124276
12/02/11 09:46 AM
12/02/11 09:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How long does it take to replace a CV axle shaft In a 96 Voyager?
This ...
How long it actually takes and what you actually get charged are 2 different things.
It seems that some people do not understand what they are reading or know how to actually answer a question.
Re: How long does it take to replace a CV axle shaft [Re: dOrk !] #1124277
12/02/11 09:49 AM
12/02/11 09:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Never did I say it would take an hour . Depending on model and year book time is between 1 and 1.5 hours per side. Flat rate techs get paid book time. So if they can do it under this time, they MAKE money. Should it take them More than book time, guess what they LOSE money. Welcome to the world of a flat rate tech.
With NO problems I could probably do both sides in 20 minutes from the time it's racked to the time it's back down on the floor, this is NO test drive and NO ck out time.
Am I going to charge more than that?????,
you bet your cotten picken butt I am, tools and knowledge ARE worth something.
Re: How long does it take to replace a CV axle shaft [Re: 71yelladustr] #1124278
12/02/11 10:23 AM
12/02/11 10:23 AM
Jacksonville Florida
elitecustombody Offline
Re: How long does it take to replace a CV axle shaft [Re: V194] #1124279
12/02/11 11:32 AM
12/02/11 11:32 AM
dogdays Offline
dogdays  Offline
It'll cost whatever the flat rate says plus incidentals and tax. Call the service writer and he should be able to tell you TO THE PENNY what the charge will be. No need to guess.
I used to be upset at those $80/hr (now closer to $150/hr) labor rates until I thought about how much money I'd have to handle in a day to pay for overhead and insurance and a wage if I was in business for myself. It'll flat floor you when you think in those terms. And that's every day. There's no garage fairy doling out money to needy shop owners. Even the large auto dealerships stay in business by selling service.
So if you can't pay the time, don't do the crime. I do most of my own work because I can't afford $80 to change transmission fluid on a car with no changeable filter. Just drain and refill, $80. Five quarts at $6 a quart because it's an import using special synthetic was my total outlay. Changing 4 spark plugs and new wires on a DOHC motor with the plugs right on top? $150. Cost me $48. But my garage is already paid for and I have a fulltime job. Home labor pays $0.
Someone else mentioned knowledge and tools. That's huge. Take away either and you are looking at the possibility of enormous bills to make it right after you have boogered it up. Also, I am an engineer. What makes me twice as valuable as a kid fresh out of college? Experience and specialized knowledge that you don't get in school. That's all, but it's major.
Off my soapbox,
R.
