ROCKER ARM PARTS REPLACEMENT??? #1124177
11/29/11 05:49 PM
11/29/11 05:49 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I'm looking to upgrade my rocker arm shaft supports and spacer springs over the winter. My current set-up is a MP blue aluminum block supports,and spring spacers. I'd like to go with something more DURABLE. I sent the set-up to RAS a few yrs ago,and they bronze-bushed the rockers..replaced all the adjusting hardware,and banana-grooved the oil holes on the shafts. I run a .620 lift(1.6 rockers)/266 duration SQ solid flat tappet Comp cam in a 440. I shift at 62-6300 rpm,and trap at 67-6800 rpm. Thanks in advance for your help! Randy B.
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: Labratt] #1124178
11/29/11 06:05 PM
11/29/11 06:05 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: Labratt] #1124179
11/29/11 06:05 PM
11/29/11 06:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats wrong with those Randy... I would run a steel
.015 rocker arm spacer next to the alum hold downs
to protect them from wear
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: MR_P_BODY] #1124180
11/29/11 06:33 PM
11/29/11 06:33 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Hughes has some nice ones
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: 65dragnet] #1124181
11/29/11 06:36 PM
11/29/11 06:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Randy these are Hughes rockers and all their holdown hardware. Works great for me. Ton
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: MR_P_BODY] #1124182
11/29/11 07:12 PM
11/29/11 07:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also ditch the springs for a solid spacer and set your side clearance .
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: Labratt] #1124183
11/29/11 09:34 PM
11/29/11 09:34 PM
AndyF Online content
AndyF  Online Content
Those aluminum hold downs wear out really quickly if you don't have a hardened shim between the rocker arm and the hold down. I learned that lesson once myself!
Low buck setup is to just put some hard shims in there. You should also have hard shims on the other side of the rocker arms between the spring and the rocker. Total cost for that upgrade is just a few bucks for a pack of shims.
Better upgrade is to put the nice steel hold downs on there that Hughes sells. Even with the steel hold downs you should use a hard shim on each side of the rocker arm.
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: AndyF] #1124184
11/29/11 10:45 PM
11/29/11 10:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
One stop shopping at Mancini for the Hughes hold down kit and spacer kit with shims to center the rocker on the valve stems
Gus
64 Plymouth Savoy
Dana 60
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: fourgearsavoy] #1124185
11/30/11 12:54 AM
11/30/11 12:54 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Andy..Gus! Looks like that Hughes set-up is the way to go! Gus,is that the set-up on your 493? Do you remember what you paid for them? I'll be in Mancini's neighborhood soon enough!
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: Labratt] #1124186
11/30/11 09:36 PM
11/30/11 09:36 PM
Rittman Ohio
Rittman Ohio
Yes Randy that is a pic of my 493 with RAS prepped Isky rockers with RAS shafts and the Hughes hold down kit with studs.
I used the kit from Mancini MREHU7442 and just drove over to the Harland Sharp factory/shop with a head and the rockers and they checked out what I was doing and sold me the spacers and shims for $30.00 I got more shims and spacers than I needed.It's nice they are only about 45 minutes from my house.All you really have to do is measure the space between the rockers and order the proper spacer kit from Mancini.
Gus
64 Plymouth Savoy
Dana 60
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: fourgearsavoy] #1124187
12/01/11 02:42 PM
12/01/11 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty sure the Hughes holddowns are RAS hold downs. I bought my first set from Hughes and have another set that came with a set of ductiles I bought that were just done by RAS .
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: JohnRR] #1124188
12/01/11 05:34 PM
12/01/11 05:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: JohnRR] #1124189
12/01/11 07:15 PM
12/01/11 07:15 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
... John,what problem did you have with them?
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: Labratt] #1124190
12/02/11 09:49 AM
12/02/11 09:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No problems
Someone either made a post a mod did not like and it was deleted , or someone deleted their post ???
Move along , nothing to see ...
Re: ROCKER ARM PARTS REPLACEMENT??? [Re: JohnRR] #1124191
12/02/11 12:32 PM
12/02/11 12:32 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Gotcha!
