Re: ROCKER ARM PARTS REPLACEMENT???
[Re: Labratt]
#1124179
11/29/11 06:05 PM
11/29/11 06:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats wrong with those Randy... I would run a steel .015 rocker arm spacer next to the alum hold downs to protect them from wear
[Re: MR_P_BODY]
#1124182
11/29/11 07:12 PM
11/29/11 07:12 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Also ditch the springs for a solid spacer and set your side clearance .
[Re: Labratt]
#1124186
11/30/11 09:36 PM
11/30/11 09:36 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yes Randy that is a pic of my 493 with RAS prepped Isky rockers with RAS shafts and the Hughes hold down kit with studs. I used the kit from Mancini MREHU7442 and just drove over to the Harland Sharp factory/shop with a head and the rockers and they checked out what I was doing and sold me the spacers and shims for $30.00 I got more shims and spacers than I needed.It's nice they are only about 45 minutes from my house.All you really have to do is measure the space between the rockers and order the proper spacer kit from Mancini. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Labratt]
#1124190
12/02/11 09:49 AM
12/02/11 09:49 AM
JohnRR
U.S.S.A.
... John,what problem did you have with them?
No problems
Someone either made a post a mod did not like and it was deleted , or someone deleted their post ???
Move along , nothing to see ...
