XE268 Cam Question #112344
08/29/08 10:30 PM
08/29/08 10:30 PM
Anonymous OP
Anonymous OP
anyone has this came in there car..this question is for you..
is it a loopy cam?? i just got an engine running with this cam that was in it when i got it, it feels a little loopy is it like that??
its a 360 with headers and pluged smog heads..
Re: XE268 Cam Question #112345
08/29/08 10:39 PM
08/29/08 10:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It has a bit of a lope to it. Not crazy, but, noticeable.
Re: XE268 Cam Question #112346
08/29/08 10:43 PM
08/29/08 10:43 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
The Comp Cams catalogue says great for street machines stock converter, slightly rough idle.
I purchased the next largerst cam. The XE274. Im hoping it wont be a little much for me. Im running 10 to 1 Ross pistons, XE274 and not really sure if Im gonna run headers or not. I may need to on this cam. I do plan to run a little more than a stock converter, maybe 2800ish.
Re: XE268 Cam Question [Re: RobX4406] #112347
08/29/08 10:45 PM
08/29/08 10:45 PM
Anonymous OP
Anonymous OP
yep mine sounds the same.. i did a quick youtube search and found the sound to the same as mine.. i thought it would be smother idle.. but it sounds beefy & good..
Re: XE268 Cam Question #112348
08/29/08 10:48 PM
08/29/08 10:48 PM
RobX4406 Offline
RobX4406  Offline
Re: XE268 Cam Question #112349
08/29/08 10:53 PM
08/29/08 10:53 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
depends what size engine.smaller engine , more lope.more inital timeing helps to tame the idle.i run about 20 inital,35 total. my 400 with 268xe has only a tiny bit of lope to it.sounds about stock to me.on the other hand, my 440 with 292 magnum sounds like an engine should.
Re: XE268 Cam Question [Re: RobX4406] #112350
08/29/08 10:56 PM
08/29/08 10:56 PM
Anonymous OP
Anonymous OP
http://s16.photobucket.com/albums/b50/opkyle/?action=view&current=DemonontheRoad009.flv
That's Demonkyles 360 with a xe268 and flowmaster
yep it sounds just like mine.. nice car, the stock ralleys makes look even better..
Re: XE268 Cam Question #112351
08/29/08 11:04 PM
08/29/08 11:04 PM
oklahoma
oklahoma
that car sounds good. i bet that is a great cam for a 360. dulcich has built several small blocks with that cam i think.
Re: XE268 Cam Question [Re: forphorty] #112352
08/29/08 11:08 PM
08/29/08 11:08 PM
RobX4406 Offline
RobX4406  Offline
It's a neat little car.
Engine made about 350HP and 400 TQ. Ran right at 102mph at MATS with a 2.94 rear gear and rolling easy off the line. He didn't want to break the 7 1/4 rear that's currently in the car. I think the car was capable of about 104 or so if we tuned it up a bit. The carb a 750DP, straight out of the box, no changes.
Re: XE268 Cam Question [Re: RobX4406] #112353
08/30/08 09:01 AM
08/30/08 09:01 AM
Nebraska
71blueduster Offline
super street
super street
Nebraska
I've got that cam in my 340 and it sounds pretty similar at idle as the car in that video.
