Re: Questions for the owners of factory sunroof cars.
[Re: challenger6pack]
#1123380
11/28/11 09:21 PM
11/28/11 09:21 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Hi Tod, When you say complete do you mean the whole roof ??? If so the best avenue would be to run it through the cycle and see how well it works...Parts are tough to find....My would be to use the E-body set-up if it's in good useable condition...If it's shot then I would'nt waste time or money and just snag a good working unit with as much of the donor roof panel as you can get....
[Re: OldMoparMan]
#1123387
01/13/12 01:37 PM
01/13/12 01:37 PM
Posts: 2,920 Calgary, Alberta Canada
a12rag
I have a 74 dart sport with the hand crank factory sunroof which is badly worn. The block where the draw wires run through is so badly worn that the roof won't close without extra help pushing it up. If your going to use the old roof make sure it is working smoothly before installing it, parts for these are hard to find
I have a 74 Duster360 with same issue. Although after looking at it for a long time, I think the thing to do is get a new gear made (the one that is the hand crank)that is a couple of mm larger in diameter, and that will engage the cables better, allowing it to close the roof.
Mark
[Re: a12rag]
#1123389
01/13/12 05:51 PM
01/13/12 05:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mark
Cable or Electric ASC sunroofs: the problem with the "drive system" for the cables is not the gear (there's only one) it's the block that holds the gear, it's aluminum, and what happens is over the years the aluminum wears away where the cables are guided by the channels cast into the drive block that the gear meshes with both cables to open/close the panel,as the channels wear they loose contact/mesh with the crank gear (regardless hand/elec.)....the only cure is machine a channel drive block out of steel, then double case harden it for wear, this is what I've done for customers sunroof cars in the past....it's not an elaborate piece to machince
Mike
[Re: a12rag]
#1123391
01/13/12 08:52 PM
01/13/12 08:52 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Cool to hear . . . Originally I was told the cables wear (?!?!?!) - uhhh, nuts to that I figured. Would be easier to get the block made than another gear ! Guess I am gonna have to find a machinist up here to look at it ! Yes, either way, getting the gear to mesh with the cable is the trick !
Thanks,
Mark
Although the cables are tuff stuff, they can get corroded, or worn just where you need them to "grab"....if the cables are indeed worn, which I have seen in some applications, you can remove the cables and swap them side to side/end for end,...the end that is crimped on the the rear adjuster can be pried free, just take your time as the adjuster is potmetal....think of it like swapping out a remote cable on a drivers door remote mirror
[Re: DAYCLONA]
#1123394
01/13/12 09:01 PM
01/13/12 09:01 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1123395
01/13/12 09:03 PM
01/13/12 09:03 PM
Posts: 18,157 Mass
DAYCLONA
Mass
