Hiding the HEI module, mech regulator cars....
#1122777
11/28/11 12:31 AM
11/28/11 12:31 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I plan to run an HEI module on my mopar electronic distributor. Came up with a creative place to put it.
It will look odd, since I plan to use the solidstate regulator to run the alternator, but the strange looks will be worth it.
Re: Hiding the HEI module, mech regulator cars....
[Re: NTOLERANCE]
#1122778
11/28/11 12:33 AM
11/28/11 12:33 AM
NTOLERANCE
Madison Wi
Second pic. If you remove all the mechanical regulator stuff, one mounting hole and one locating hole line up. I ground the other locating tab and drilled one hole. Some dielectric grease, and if warranted an aluminum plate, and its out of sight.
(hopefully this is in the right forum this time)
[Re: NTOLERANCE]
#1122785
11/28/11 04:39 AM
11/28/11 04:39 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
it doesnt fail like the infamous ORANGE box does..
cheaper if it does fail
havnt seen the disr adapter plate lately. Is it still out there?
I am truckless..
[Re: 340SHORTY]
#1122786
11/28/11 08:10 AM
11/28/11 08:10 AM
Posts: 11,080 Berlin, N.J.
abodyjoe
Berlin, N.J.
a second voltage regulator?? not sure that looks right. why not gut a normal ecu and wire it to the pins and use the stock electronic style plug.. even this little bracket http://www.designed2drive.com/ would look a lot cleaner then a second regulator.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#1122787
11/28/11 08:22 AM
11/28/11 08:22 AM
abodyjoe
Berlin, N.J.
[Re: JohnRR]
#1122791
11/28/11 12:07 PM
11/28/11 12:07 PM
RapidRobert
Thanks Dawg, I'll call/visit RS
[Re: NTOLERANCE]
#1122792
12/01/11 12:59 PM
12/01/11 12:59 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
why don't you make what Don's at FBO is making with the "Brand new "Mopar" Ecu module"?. Find some old ECU, remove the inners and fit inside the HEI, module, using the stock 5 pins ECU plug
