Re: Oil Pan Mods
[Re: camdog440]
#1122444
11/27/11 04:28 PM
11/27/11 04:28 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Take a look at the 4WD pans for your motor. They have sumps located to the rear of drag link.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Oil Pan Mods
[Re: Cab_Burge]
#1122448
11/28/11 09:14 AM
11/28/11 09:14 AM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
It's a 440. I bought a nice aluminum drive shaft off of the bullet a while back that was supposed to be the perfect length for my application... the guy didn't measure correctly, though, and it came up short. I decided to go ahead and use it but I have to move my engine back almost 2" further than I had planned. Now my current pan interferes with the steering link. If I were to use that pan I would have to notch it a couple of inches on the back to clear the steering link.
If your moving the motor back why not convert the car to a front steer rack and pinion mounted in front of the K memeber and loose some weight and keep the same oil pan?
That is a good idea. The only reason that I can't do that right now is the limit of the function to the inverse of the thickness of my wallet as x approaches zero.
Re: Oil Pan Mods
[Re: camdog440]
#1122449
11/28/11 11:39 AM
11/28/11 11:39 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
I noticed you stated you were MOCKING UP your engine. Have you already made your mount fabrications? Auto or stick car? Asking because of header clearance, trans dipstick location, firewall to bell housing pita. Also to mention oil pump to engine mount. A salvage yard mustang 2 rack and some fabbed pieces does sound easier and cheaper. I also believe B Body rear leaf springs has a 1 inch shorter front segment than the e body springs. Of course the most simple and quickest way would be to sell the wrong driveshaft and buy the right one, if your money was tight as you claim Food for thought
Re: Oil Pan Mods
[Re: Mopar-Al]
#1122451
11/28/11 06:23 PM
11/28/11 06:23 PM
BradH
Of course the most simple and quickest way would be to sell the wrong driveshaft and buy the right one...
Seemed obvious to me, too. But what do I know...
